Compatibility from OF 1.6 to OF 1.7?
Old   July 6, 2010, 04:32
Default Compatibility from OF 1.6 to OF 1.7?
Chrisi1984 is on a distinguished road
At the moment I am using OF 1.6.
Can I still run my cases and solvers of OF 1.6 in OF 1.7? Which problems can occure? Has anyone of you any experiences with this problem?
What would you reccomend to do?
Regards Chrisi
Chrisi1984 is offline   Reply With Quote
Old   July 7, 2010, 02:18
Gijsbert Wierink
gwierink is on a distinguished road
Hi Chrisi,
Well, I suppose it depends on which solver (or solver family) you use. For instance, in 1.7 the pressure has been changed to p_rgh=p-rho*g*x for multiphase solvers. I haven't tried it myself yet, but have a look at the new features/changes of OpenCFD and see if anything is relevant for your solver.
Regards, Gijs
gwierink is offline   Reply With Quote
Old   July 7, 2010, 03:07
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by gwierink View Post
Hi Chrisi,
Note that the git repository for 1.7.x is compatible with 1.6.x, so you can also do the following:
git remote add github git://github.com/OpenCFD/OpenFOAM-1.7.x.git
git fetch github
Now you can see the changes (with git diff or git log) between the versions and do a git merge to update your setup as required.
olesen is offline   Reply With Quote
k-omega-SST model (OF 1.6) - turbulent flat plate cboss OpenFOAM Running, Solving & CFD 25 August 9, 2016 09:53
install OpenFoam 1.6 by building source: how? niudie OpenFOAM Installation 13 April 26, 2011 00:48
problems in Two Phase flow using twoPhaseEulerFoam with OpenFoam 1.6 raagh77 OpenFOAM Running, Solving & CFD 0 March 6, 2010 05:11
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 17:55
MixSim 1.7 Tutorials johnnyb FLUENT 0 August 25, 2003 17:13
