Building 1.6-dev on Ubuntu 10.10 (64bit)
Like Tree1Likes
  • 1 Post By andrewryan
Old   February 21, 2011, 14:24
Unhappy Building 1.6-ext on Ubuntu 10.10 (64bit)
Andrew Ryan
andrewryan is on a distinguished road
Hi all
I'm trying to build 1.6-ext. I first ran into the problem that the build system could not find 'mpi.h', which I fixed by setting..
export WM_MPLIB=SYSTEMOPENMPI
However I also ran in another error, which I don't understand:
SOURCE=scotchDecomp.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I -I../decompositionMethods/lnInclude -IlnInclude -I. -I/home/nils/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/nils/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/scotchDecomp.o
In file included from scotchDecomp.C:108:
scotchDecomp.H:39: fatal error: decompositionMethod.H: No such file or directory
compilation terminated.
The file however is where it should:
OpenFOAM-1.6-ext > find . -name decompositionMethod.H
./src/decompositionMethods/decompositionMethods/decompositionMethod/decompositionMethod.H
./src/decompositionMethods/decompositionMethods/lnInclude/decompositionMethod.H
Thx for help!
The full log is here: http://codepad.org/eSoJts5M
andrewryan is offline   Reply With Quote
Old   February 24, 2011, 07:15
Andrew Ryan
Got it working You basically have to build ThirdParty first. I built it first including qt, then it more or less worked fine.. IIRC I had to set an include path manually (to the include file in third party), because otherwise I ran into could not find mpi.h..
peterhess likes this.
Old   March 1, 2011, 09:05
Unhappy :(
Andrew Ryan
I just noticed that some of the packages, built in the ThirdParty directory actually replace Ubuntu packages For example the cmake package. Found this quite annoying the package name of the ThirdParty packages for OF ext should differ from the Ubuntu packages so you can have both installed at the same time.
Old   March 9, 2011, 09:53
David Gaden
marupio is on a distinguished road
My ThirdParty built fine, but I still encountered this problem:
SOURCE=scotchDecomp.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I -I../decompositionMethods/lnInclude -IlnInclude -I. -I/home/dave/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/dave/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/scotchDecomp.o
scotchDecomp.H:39:33: error: decompositionMethod.H: No such file or directory
scotchDecomp.C:117:20: error: scotch.h: No such file or directory
Messing around with the Make/options didn't work. Does anyone have any idea?
EDIT: I had to re-source the bashrc file. Now the installation gets past this error, and moves on to the next one...
marupio is offline   Reply With Quote
Old   May 21, 2011, 06:37
Hector Redal
HectorRedal is on a distinguished road
I have found the same problem stated in this thread.
Have someone manage to solve it?
How can I proceed further?
Best regards,
Hector.
HectorRedal is offline   Reply With Quote
Old   July 2, 2013, 15:27
Default Set variable SCOTCH_INCLUDE_DIR
Jean-Luc Pelerin
jlpelerin is on a distinguished road
Hi All,
It also seems to work to set the variable SCOTCH_INCLUDE_DIR to point toward the scotch include directory (installed from the Ubuntu package).
Regards,
Jean-Luc
jlpelerin is offline   Reply With Quote
1.6-ext
Ansys 12.0 on Ubuntu 10.10 64bit Krischan ANSYS 1 April 26, 2011 04:44
install OpenFoam 1.6 by building source: how? niudie OpenFOAM Installation 13 April 26, 2011 00:48
OpenFOAM vs Ubuntu 10.10 64 bit vkrastev OpenFOAM Installation 12 April 23, 2011 10:14
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
