May 1, 2009, 21:10 |
OpenFOAM static build on Cray XT5
Rep Power: 17 |
Hi, all.
I want to report the partiallly successful compilation of OpenFOAM on Cray XT5. As you know, Cray XT5 uses CNL for their node exectuion, so I had to compile the OpenFOAM statically. I could compile almost all solvers and utilities (but some of them didn't work correctly.) I think it's easy to apply these procedures to other static-linked only platforms. Here is the recipe: 0. Switch to GNU compiler (for Cray XT5 module system) $ module swap PrgEnv-pgi PrgEnv-gnu 1. Expand OpenFOAM-1.5.x.tar.gz (fetched from git repo) and ThirdParty.tar.gz into the CNL-accesible directory and remove the needless libraries (malloc, zlib and openmpi) in ./ThirdParty. Edit ThirdParty/Allwmake to comment out malloc and zlib build directives. NOTE: if you want to use openmpi attached in ThirdParty.tar.gz, you must modify openmpi build configure script in Allwmake. Change "--enable-shared --disable-static" to "--disable-shared --enable-static", and add "--without-memory-manager --without-libnuma". cf. http://www.open-mpi.org/faq/?category=mpi-apps#static-mpi-apps 2. Edit etc/{bashrc,settings.sh}: bashrc: foamInstall=$YOUR_INSTALLED_DIR/$WM_PROJECT WM_PROJECT_USER_DIR=$FOAM_INST_DIR/$USER-$WM_PROJECT_VERSION WM_MPLIB=MPICH settings.sh: comilerInstall=OpenFOAM => System case "$WM_MPLIB" in ... MPICH) => MPICH_ORG) .... MPI) => MPICH) export MPI_ARCH_PATH=$MPICH_DIR export FOAM_MPI_LIBBIN=$FOAM_LIBBIN Finally, read all configurations. $ . etc/bashrc 3. Change libso to libo in all Allwmake: $ cd $FOAM_INST_DIR $ find -name Allwmake -exec ruby -p -i.bak -e"gsub(/libso/, 'libo')" {} \; And make solvers not to link indivisual libraries: $ find -name options -exec ruby -p -i.bak -e"gsub(/EXE_LIBS/, 'EXE_LIBS_ORG')" {} \; 4. Comment out all codes relevant with libdl functions: You can find them by executing this on shell: $ find -name "*.C" -exec grep -nH dlfcn {} \; ./src/OpenFOAM/db/dlLibraryTable/dlLibraryTable.C:29:#include <dlfcn.h> ./src/OSspecific/Unix/printStack.C:36:#include <dlfcn.h> And in $WM_PROJECT_DIR/wmake/rules/$WM_ARCH$WM_COMPILER/general, replace "-ldl" by "-lz". 5. Make all libraries: $ cd $WM_PROJECT_DIR Comment out "(cd applications ..." in Allwmake. $ export WM_NCOMPPROCS=2; ./Allwmake 6. Make the whole OpenFOAM library: $ cd $FOAM_LIBBIN $ ar rcvs libOpenFOAM.a lib*.o 7. Make solvers & utilities Edit $WM_PROJECT_DIR/wmake/rules/$WM_ARCH$WM_COMPILER/c++ to change the compiler and environment variable: CC = g++ => CC (or mpiCC) LINK_LIBS = $(c++DBUG) => -static -Wl,--allow-multiple-definition $ cd $FOAM_APP $ ./Allwmake Known Problems: * The "functionObjectLibs" directive doesn't work because it loads shared library. * Linker option "--allow-multiple-definition" suppresses errors of multiple definition of the lexers. I don't have any ideas about what side-effects it bring on. Cheers, asaijo |
How can I build OpenFOAM in cygwin | joywe | OpenFOAM Installation | 10 | September 12, 2008 09:39 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Build OpenFOAM on MacOSX | Mauro Augelli (Augelli) | OpenFOAM Installation | 101 | July 21, 2008 06:42 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
OpenFOAM build from source instructions | tj22 | OpenFOAM Installation | 7 | April 6, 2006 16:15 |
