June 9, 2011, 01:56 |
OpenFoam 1.6-ext - error ./Allwmake in /src
Stefan
Rep Power: 16 |
after installing the thirdparty software, I have a problem by doing ./Allwmake in /src Code:
+ wmakePrintBuild -check no git description found + /bin/rm -f OpenFOAM/Make/linux64GccDPOpt/global.C + wmakeLnInclude OpenFOAM + wmakeLnInclude OSspecific/POSIX + Pstream/Allwmake + wmake libso dummy '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/dummy/libPstream.so' is up to date. + case "$WM_MPLIB" in + set +x Note: ignore spurious warnings about missing mpicxx.h headers + WM_OPTIONS=linux64GccDPOptOPENMPI + wmake libso mpi '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/openmpi-1.4.3/libPstream.so' is up to date. + wmake libo OSspecific/POSIX '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libOSspecific.o' is up to date. + wmake libso OpenFOAM SOURCE=global/global.Cver ; sed -e 's/VERSION_STRING/1.6-ext/' -e 's/BUILD_STRING/1.6-ext/' $SOURCE > Make/linux64GccDPOpt/global.C; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linux64GccDPOpt/global.C -o Make/linux64GccDPOpt/global.o SOURCE=db/IOstreams/gzstream/gzstream.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/gzstream.o In file included from db/IOstreams/gzstream/gzstream.C:29: db/IOstreams/gzstream/gzstream.h:35:18: error: zlib.h: Datei oder Verzeichnis nicht gefunden In file included from db/IOstreams/gzstream/gzstream.C:29: db/IOstreams/gzstream/gzstream.h:62: error: ‘gzFile’ does not name a type db/IOstreams/gzstream/gzstream.C: In member function ‘gzstreambuf* gzstreambuf::open(const char*, int)’: db/IOstreams/gzstream/gzstream.C:61: error: ‘file’ was not declared in this scope db/IOstreams/gzstream/gzstream.C:61: error: ‘gzopen’ was not declared in this scope db/IOstreams/gzstream/gzstream.C: In member function ‘gzstreambuf* gzstreambuf::close()’: db/IOstreams/gzstream/gzstream.C:72: error: ‘file’ was not declared in this scope db/IOstreams/gzstream/gzstream.C:72: error: ‘gzclose’ was not declared in this scope db/IOstreams/gzstream/gzstream.C:72: error: ‘Z_OK’ was not declared in this scope db/IOstreams/gzstream/gzstream.C: In member function ‘virtual int gzstreambuf::underflow()’: db/IOstreams/gzstream/gzstream.C:90: error: ‘file’ was not declared in this scope db/IOstreams/gzstream/gzstream.C:90: error: ‘gzread’ was not declared in this scope db/IOstreams/gzstream/gzstream.C: In member function ‘int gzstreambuf::flush_buffer()’: db/IOstreams/gzstream/gzstream.C:107: error: ‘file’ was not declared in this scope db/IOstreams/gzstream/gzstream.C:107: error: ‘gzwrite’ was not declared in this scope make: *** [Make/linux64GccDPOpt/gzstream.o] Fehler 1 Preibie |
June 9, 2011, 03:21 |
Anton Kidess
Rep Power: 30 |
It looks like your system is missing the zlib library.
edit: Make sure you have all the following packages installed before you attempt to compile: http://openfoamwiki.net/index.php/In...eeded_Packages Last edited by akidess; June 9, 2011 at 03:23. Reason: Added more information |
June 9, 2011, 08:34 |
Stefan
Rep Power: 16 |
I tried to install the packages. Some of them are not in the standard repository of suse enterprise:
python-dev libqt4-dev libreadline5-dev build-essential zlib1g-dev byacc Can someone give me an advice how I can install them. Do I need to install git for 1.6-ext? |
June 9, 2011, 08:49 |
Anton Kidess
Rep Power: 30 |
They will be there, but named slightly different (*sigh*). I believe SuSE denotes developer packages with "devel" instead of "dev". About build essential see http://forums.opensuse.org/applicati...essential.html. I have no clue about the byacc package, but you can try to compile without it, maybe it's not required on SuSE.
I think you can download a tarball of OF-1.6-ext, but I recommend installing git and using git pull. Last edited by akidess; June 9, 2011 at 08:51. Reason: noticed the question about of-extend and git |
June 9, 2011, 09:04 |
Stefan
Rep Power: 16 |
devel instead of dev is not key.
June 9, 2011, 09:11 |
Anton Kidess
Rep Power: 30 |
If you would spend two minutes on google you would have found: http://software.opensuse.org/114/de
Searching there for "python-devel" gives: python-devel-2.7-8.4.i586.rpm For "libqt4-devel": libqt4-devel-4.7.1-7.1.i586.rpm I'm pretty sure there will be equivalents for the other packages, and that you would find the packages doing the same search in YaST as well. |
June 9, 2011, 09:25 |
Stefan
Rep Power: 16 |
I'am not a linux expert!
Can I use a rpm package for SLES which is made for openSuse? |
June 10, 2011, 03:29 |
Anton Kidess
Rep Power: 30 |
I'm not a linux expert either. But you might agree that "devel instead of dev is not key" does not help solve the problem at all. Better - what exactly have you tried, and why do you think it failed?
Anyway, step by step: Click Start -> System -> Configuration -> Install / Remove Software -> Enter your admin password -> (YaST will pop up) -> Click Search tab -> Search for "libqt4-devel" -> Mark the appropriate package in the search results -> Repeat for next package -> When done, click Accept -> Packages will now be installed. |
June 10, 2011, 03:52 |
#9 |
Stefan
Rep Power: 16 |
Thanks for your help!
I tried and found no package. So I ad the developer repository named SDK and found some of the missed packages. So I must search for the rest: libreadline5-dev build-essential zlib1g-dev byacc |
June 10, 2011, 04:50 |
#10 |
Anton Kidess
Rep Power: 30 |
Good job! Happy foaming!
June 14, 2011, 03:56 |
#11 |
Stefan
Rep Power: 16 |
Hello again,
after installing the missing packages I tried ./Allwmake but something is still wrong. Here is the output till the first error. Code:
make: Für das Ziel »all« ist nichts zu tun. + wmakePrintBuild -check same version as previous build + wmakeLnInclude OpenFOAM + wmakeLnInclude OSspecific/POSIX + Pstream/Allwmake + wmake libso dummy '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/dummy/libPstream.so' is up to date. + case "$WM_MPLIB" in + set +x Note: ignore spurious warnings about missing mpicxx.h headers + WM_OPTIONS=linux64GccDPOptOPENMPI + wmake libso mpi '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/openmpi-1.4.3/libPstream.so' is up to date. + wmake libo OSspecific/POSIX '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libOSspecific.o' is up to date. + wmake libso OpenFOAM SOURCE=global/global.Cver ; sed -e 's/VERSION_STRING/1.6-ext/' -e 's/BUILD_STRING/1.6-ext-b2b3a4ef31f5/' $SOURCE > Make/linux64GccDPOpt/global.C; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linux64GccDPOpt/global.C -o Make/linux64GccDPOpt/global.o '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libOpenFOAM.so' is up to date. + decompositionMethods/AllwmakeLnInclude + wmakeLnInclude decompositionMethods + wmakeLnInclude metisDecomp + wmakeLnInclude parMetisDecomp + wmakeLnInclude scotchDecomp + decompositionMethods/Allwmake + wmakeLnInclude decompositionMethods + wmake libso scotchDecomp '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libscotchDecomp.so' is up to date. + wmake libso metisDecomp '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libmetisDecomp.so' is up to date. + wmake libso parMetisDecomp '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/openmpi-1.4.3/libparMetisDecomp.so' is up to date. + wmake libso decompositionMethods '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libdecompositionMethods.so' is up to date. + wmake libso lagrangian/basic '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/liblagrangian.so' is up to date. + wmake libso triSurface '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libtriSurface.so' is up to date. + wmake libso edgeMesh '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libedgeMesh.so' is up to date. + wmake libso surfMesh '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libsurfMesh.so' is up to date. + wmake libso meshTools '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libmeshTools.so' is up to date. + wmake libso finiteVolume '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libfiniteVolume.so' is up to date. + wmake libso finiteArea '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libfiniteArea.so' is up to date. + wmake libso lduSolvers '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/liblduSolvers.so' is up to date. + wmake libso VectorN '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libVectorN.so' is up to date. + cd tetDecompositionFiniteElement + ./Allwmake '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libcellDecompFiniteElement.so' is up to date. '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libfaceDecompFiniteElement.so' is up to date. + dynamicMesh/AllwmakeLnInclude + wmakeLnInclude dynamicMesh + wmakeLnInclude dynamicFvMesh + wmakeLnInclude topoChangerFvMesh + meshMotion/AllwmakeLnInclude + wmakeLnInclude solidBodyMotion + wmakeLnInclude fvMotionSolver + wmakeLnInclude RBFMotionSolver + wmakeLnInclude mesquiteMotionSolver + dynamicMesh/Allwmake + wmakeLnInclude dynamicMesh + wmake libso dynamicMesh '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libdynamicMesh.so' is up to date. + meshMotion/Allwmake + wmake libso solidBodyMotion '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libsolidBodyMotion.so' is up to date. + wmake libso fvMotionSolver '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libfvMotionSolver.so' is up to date. + wmake libso RBFMotionSolver '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libRBFMotionSolver.so' is up to date. + wmake libso mesquiteMotionSolver '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libmesquiteMotionSolver.so' is up to date. + cd tetDecompositionMotionSolver + ./Allwmake '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libcellDecompositionMotionSolver.so' is up to date. '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libfaceDecompositionMotionSolver.so' is up to date. + wmake libso dynamicFvMesh '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libdynamicFvMesh.so' is up to date. + wmake libso topoChangerFvMesh '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libtopoChangerFvMesh.so' is up to date. + wmake libso coupledMatrix '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libcoupledLduMatrix.so' is up to date. + wmake libso sampling '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libsampling.so' is up to date. + wmake libso ODE '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libODE.so' is up to date. + wmake libso POD '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libPOD.so' is up to date. + wmake libso randomProcesses '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/librandomProcesses.so' is up to date. + thermophysicalModels/Allwmake + wmake libso specie '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libspecie.so' is up to date. + wmake libso thermophysicalFunctions '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libthermophysicalFunctions.so' is up to date. + wmake libso liquids '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libliquids.so' is up to date. + wmake libso liquidMixture '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libliquidMixture.so' is up to date. + wmake libso solids '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libsolids.so' is up to date. + wmake libso solidMixture '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libsolidMixture.so' is up to date. + wmake libso basic '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libbasicThermophysicalModels.so' is up to date. + wmake libso reactionThermo '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libreactionThermophysicalModels.so' is up to date. + wmake libso laminarFlameSpeed '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/liblaminarFlameSpeedModels.so' is up to date. + wmake libso chemistryModel '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libchemistryModel.so' is up to date. + wmake libso pdfs '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libpdf.so' is up to date. + wmake libso radiation '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libradiation.so' is up to date. + wmake libso barotropicCompressibilityModel '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libbarotropicCompressibilityModel.so' is up to date. + transportModels/Allwmake + wmake libso incompressible '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libincompressibleTransportModels.so' is up to date. + wmake libso interfaceProperties '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libinterfaceProperties.so' is up to date. + wmake libso viscoelastic '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libviscoelasticTransportModels.so' is up to date. + turbulenceModels/Allwmake + LES/Allwmake + wmakeLnInclude ../incompressible/LES + wmake libso LESfilters '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libLESfilters.so' is up to date. + wmake libso LESdeltas '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libLESdeltas.so' is up to date. + incompressible/Allwmake + wmake libso turbulenceModel '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libincompressibleTurbulenceModel.so' is up to date. + wmake libso RAS '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libincompressibleRASModels.so' is up to date. + wmake libso LES '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libincompressibleLESModels.so' is up to date. + compressible/Allwmake + wmake libso turbulenceModel '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libcompressibleTurbulenceModel.so' is up to date. + wmake libso RAS '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libcompressibleRASModels.so' is up to date. + wmake libso LES '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libcompressibleLESModels.so' is up to date. + lagrangian/Allwmake + wmake libso basic '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/liblagrangian.so' is up to date. + wmake libso solidParticle '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libsolidParticle.so' is up to date. + wmake libso intermediate '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/liblagrangianIntermediate.so' is up to date. + wmake libso dieselSpray '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libdieselSpray.so' is up to date. + wmake libso dsmc '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libdsmc.so' is up to date. + wmake libso coalCombustion '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libcoalCombustion.so' is up to date. + molecularDynamics/Allwmake + wmake libso potential '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libpotential.so' is up to date. + wmake libso molecularMeasurements '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libmolecularMeasurements.so' is up to date. + wmake libso molecule '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libmolecule.so' is up to date. + postProcessing/Allwmake + wmake libo postCalc '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/postCalc.o' is up to date. + wmake libso foamCalcFunctions '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libfoamCalcFunctions.so' is up to date. + functionObjects/Allwmake + wmake libso check '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libcheckFunctionObjects.so' is up to date. + wmake libso field '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libfieldFunctionObjects.so' is up to date. + wmake libso forces '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libforces.so' is up to date. + wmake libso IO '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libIOFunctionObjects.so' is up to date. + wmake libso utilities '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libutilityFunctionObjects.so' is up to date. + wmake libso systemCall '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libsystemCall.so' is up to date. + conversion/Allwmake + wmake libso '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libconversion.so' is up to date. + wmake libso autoMesh '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libautoMesh.so' is up to date. + wmake libso errorEstimation '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/liberrorEstimation.so' is up to date. + fvAgglomerationMethods/Allwmake + wmake libso MGridGenGamgAgglomeration '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libMGridGenGAMGAgglomeration.so' is up to date. + wmake libso engine '/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libengine.so' is up to date. + wmake all solvers g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/laplacianFoam.o -L/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \ -lfiniteVolume -llduSolvers -lOpenFOAM -liberty -ldl -lm -o /home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/laplacianFoam g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I../engineFoam -I../XiFoam -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/engine/lnInclude -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/specie/lnInclude -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/basic/lnInclude -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/reactionThermo/lnInclude -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/compressible/turbulenceModel -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/coldEngineFoam.o -L/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \ -lengine -lcompressibleTurbulenceModel -lcompressibleRASModels -lcompressibleLESModels -lbasicThermophysicalModels -lspecie -lfiniteVolume -llduSolvers -lOpenFOAM -liberty -ldl -lm -o /home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/coldEngineFoam /usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld: cannot find -liberty collect2: ld returned 1 exit status make[2]: *** [/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/laplacianFoam] Fehler 1 make[1]: *** [laplacianFoam] Fehler 2 /usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld: cannot find -liberty collect2: ld returned 1 exit status make[2]: *** [/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/coldEngineFoam] Fehler 1 make[1]: *** [coldEngineFoam] Fehler 2 g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/POD/lnInclude -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/ODE/lnInclude -IlnInclude -I. -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/PODSolver.o -L/home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \ -lfiniteVolume -lODE -lPOD -lOpenFOAM -liberty -ldl -lm -o /home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/PODSolver /usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld: cannot find -liberty Preibie |
June 14, 2011, 04:03 |
#12 |
Anton Kidess
Rep Power: 30 |
June 14, 2011, 04:52 |
#13 |
Stefan
Rep Power: 16 |
YES! Thanks for the fast answer!
I tried a tutorial blockMesh; icoFoam all is fine. But as I make the foamInstalltest ther is a error. Is this a problem? Code:
Executing /home/preibisch/OpenFOAM/OpenFOAM-1.6-ext/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: ansyscfd OS: Linux version 2.6.32.36-0.5-default ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/preibisch/OpenFOAM yes yes $WM_PROJECT_USER_DIR ...preibisch/OpenFOAM/preibisch-1.6-ext yes no $WM_THIRD_PARTY_DIR ...OpenFOAM/OpenFOAM-1.6-ext/ThirdParty yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR .../preibisch/OpenFOAM/OpenFOAM-1.6-ext yes yes yes $FOAM_APPBIN ...ext/applications/bin/linux64GccDPOpt yes yes yes $FOAM_SITE_APPBIN ...OAM/site/1.6-ext/bin/linux64GccDPOpt no no $FOAM_USER_APPBIN ...ext/applications/bin/linux64GccDPOpt no no $WM_DIR ...isch/OpenFOAM/OpenFOAM-1.6-ext/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OpenFOAM-1.6-ext/lib/linux64GccDPOpt yes yes yes $FOAM_SITE_LIBBIN ...OAM/site/1.6-ext/lib/linux64GccDPOpt no no $FOAM_USER_LIBBIN ...reibisch-1.6-ext/lib/linux64GccDPOpt no no $MPI_ARCH_PATH ...nmpi-1.4.3/platforms/linux64GccDPOpt yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.3 User version : 4.3.4 Minimum required: 4.3.1 gcc 4.3.4 WARNING: Conflicting installations: OpenFOAM settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.3.12 /usr/bin/gzip tar 1.20 /bin/tar icoFoam 1.6-ext ...nFOAM-1.6-ext/applications/bin/linux64GccDPOpt/icoFoam ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. |
June 14, 2011, 05:21 |
#14 |
Anton Kidess
Rep Power: 30 |
No, it's not a problem.
June 14, 2011, 05:57 |
#15 |
Stefan
Rep Power: 16 |
Test directory missing in OpenFOAM 1.6 ext | andrewryan | OpenFOAM | 2 | March 20, 2011 15:41 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
kOmegaSST in openfoam 1.6 | Gearb0x | OpenFOAM | 2 | March 3, 2010 06:02 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
OpenFOAM Version 1.6 Released | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 27, 2009 17:55 |
