[blockMesh] Flow Around A Wall
Old   July 27, 2012, 18:54
Default Flow Around A Wall
Richard
rickcjmac is on a distinguished road
I'm not sure if this is the right spot for this, but here I go. I am trying to learn OF and I've gone through the tutorials. I am trying to simulate a flow around a wall. I attached a picture of what I am using as my geometry. It is a top view. I modified the cavity example's blockmeshdict file so that the points and blocks match up, I think. I modified the patches to do likewise, with the flow going from left to right. Here is what my blockmeshdict file looks like now:
|  \\    /   O peration     | Version:  2.1.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.1;
vertices
    	(0 0 0) //  1
	(1 0 0) //  2
	(2 0 0) //  3
	(3 0 0) //  4
	(3 2 0) //  5
	(2 2 0) //  6
	(1 2 0) //  7
	(0 2 0) //  8
	(1 1 0) //  9
	(2 1 0) // 10
    	(0 0 1) // 11
	(1 0 1) // 12
	(2 0 1) // 13
	(3 0 1) // 14
	(3 2 1) // 15
	(2 2 1) // 16
	(1 2 1) // 17
	(0 2 1) // 18
	(1 1 1) // 19
	(2 1 1) // 20
blocks
    hex (0 1 6 7 10 11 16 17) (10 20 1) simpleGrading (1 1 1)
    hex (1 2 9 8 11 12 19 18) (10 10 1) simpleGrading (1 1 1)
    hex (2 3 4 5 12 13 14 15) (10 20 1) simpleGrading (1 1 1)
    hex (8 9 5 6 18 19 15 16) (10 10 1) simpleGrading (1 1 1)
edges
boundary
    movingWall
        type wall;
        faces
            (0 10 17 7)
            (8 18 16 6)
            (9 19 15 5)
	    (3 13 14 4)
    fixedWalls
        type wall;
        faces
            (0 1 11 10)
            (1 2 12 11)
            (2 3 13 12)
            (7 6 16 17)
            (6 5 15 16)
            (5 4 14 15)
            (8 9 19 18)
            (1 8 18 11)
            (2 9 19 12)
    frontAndBack
        type empty;
        faces
		(0 1 6 7)
		(1 2 9 8)
		(2 3 4 5)
		(8 9 5 6)
		(10 11 16 17)
		(11 12 19 18)
		(12 13 14 15)
		(18 19 15 16)
mergePatchPairs
Is this approach a good one? How can I get this to work? Right now it won't compile when I run blockMesh. I'm in over my head, but it would be very helpful if I could get this to work.
Thank you for your time
rickcjmac is offline   Reply With Quote
Old   July 28, 2012, 06:11
Default Internal face
Marc
Justinus is on a distinguished road
Hey Richard,
there should be an errormassage like: "Trying to specify a boundary face 4(8 9 19 18) on the face on cell 1 which is either an internal face or already belongs to some other patch."
This tells you this is an internal face.
Try a wall made out of 8 vertices. I assume you will have to define 8 blocks: 3 above your wall, 3 below, 1 left of it and 1 right of it.
Is it right you wanted to have a flow from vertices 0 1 2 3 13 12 11 10 (inlet) to vertices 7 6 5 4 14 15 16 17 ? So you still have to define them as patch like
inlet {
type patch;
faces (
(0 1 11 10)
(1 2 12 11)
(2 3 13 12)
Same for your atmosphere
and define some boundary like velocity and pressure for these patches.
Justinus is offline   Reply With Quote
flow around a wall, wall
Flow on the wall and boundary conditions Waggy System Analysis 0 February 18, 2018 01:51
Wall mesh size high Re nummer flow through duct bolus13 CFX 3 April 25, 2017 19:35
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Wall pressure interpolation for buoyant flow khaiching Main CFD Forum 2 April 28, 2010 21:04
Influece of wall velocity in the main flow marvin CFX 0 March 22, 2008 02:05
