December 9, 2012, 23:41 |
stitchMesh question?
Vishal Achasrya
Rep Power: 14 |
I have a question about stitchMesh. I have a sector geometry which has a centerline. Now when i rotatemesh and i paste, the centerline edge and nodes are common, so i assume they are not being repeated and that stitchMesh recognizes this. Now in the end when i need to stich the final internal faces that overlap to complete the geometry, i get an error.... Face XXXX reduced to less than 3 points. Now im researched this in the forum and i see that there are others who have faced this error, but i dont see any where the geometry involved the centerline. Im thinking that this error is related to my centerline? My mesh was created in gambit with a 45 degree sector that i initially used in a cyclic fashion. I converted to foam format. I have rotated and merged meshes and then stitched faces successfully for 7 times now. But the last stitch which is to stitch the final internal faces that overlaps, gives this error. I dont know why. I also have another question. If i have faces inside a mesh that are internal and perfectly overlap, can i mark them to be translational periodic? I ask this as a last resort if in case there is no way to fix the above issue. I am assuming this would still be physical in terms of solving? Please do not hesitate to ask any info that i failed to mention here. note that i do not have a blockmeshdict. Thanks in advance ! |
mergemeshes, stitchmesh |
[mesh manipulation] stitchMesh: multiple meshes | GerhardHolzinger | OpenFOAM Meshing & Mesh Conversion | 3 | August 25, 2017 12:43 |
small question about the functionalities of topological changes in OpenFoam | ngj | OpenFOAM Running, Solving & CFD | 2 | February 28, 2013 10:02 |
Question Re Engineering Data Source | imnull | ANSYS | 0 | March 5, 2012 13:51 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
