[snappyHexMesh] nCellsBetweenLevels problem
Old   March 28, 2013, 19:39
Default nCellsBetweenLevels problem
laurentL
laurent98 is on a distinguished road
hello Foamers,
i want to mesh a air-foil in 2d, i specify nCellsBetweenLevels 9 but SHM doesn't do it...
i can't find the reason, any ideas ???
laurent98 is offline   Reply With Quote
Old   April 9, 2013, 01:08
laurentL
hi to all,
i have found the problem, it seems that SHM does'nt like non cubic cells! my blockmesh wasn't thick enough.
then, i play a little with featureAngle to obtain Layers... difficult in 3D and quiet stupid because the mesh will be extrude for 2D solving. so i try this trick
make a first SHM with only castelaned true
then extrude
then a second SHM to snap and add layer
here the shell script;
#!/bin/sh
cd ${0%/*} || exit 1 # run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
# Make 3D mesh only castellated slab of cells.
cd wingMotion_snappyHexMesh1
runApplication blockMesh
cp system/snappyHexMeshDict_init system/snappyHexMeshDict;
runApplication snappyHexMesh; #-overwrite
cp system/snappyHexMeshDict2 system/snappyHexMeshDict
runApplication extrudeMesh
rm log.snappyHexMesh;
rm -r 1
# Make a 2D mesh by extruding a patch and solve to steady state.
#cd ../wingMotion2D_simpleFoam1
#runApplication extrudeMesh
#runApplication createPatch -overwrite
#runApplication simpleFoam
# ----------------------------------------------------------------- end-of-file
my problem now is that simpleFoam doesn t work well because a "empty group" appear ....
to learn OF i fill that a lot of perseverance is needed... any help will be very welcome...
LL
Old   April 11, 2013, 19:51
Default solved
laurentL
Hi
I send that just for information in case of someone got the same problem.
I just pass from OF 2.1 to 2.2
and to solve the problem i had just to change "mirror" to "empty" into the include files
lost of fun, with OF !!! LL
ncellsbetweenlevels
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
