[blockMesh] Wedge type mesh: generation OK but the mesh has bug for some cells!
Old   January 13, 2014, 04:50
Default Wedge type mesh: generation OK but the mesh has bug for some cells!
Fabien DOS SANTOS
Paebin is on a distinguished road
I'm working on a case (flow inside a nozzle) where my geometry is axisymmetric and I want to do simulation with only one quarter of it (for cpu time saving).
I create my mesk by generating a .m4 file with Matlab and then create a blockMeshDict file with this .m4 file (I know that can sound complicated, but it works).
The mesh is generating without any problem. But I have a block that gets some bad cells (you can see it on the attached image from paraview) and I don't know why! This block has only 6 vertices because it is on the axis.
I have isolated this particular block in order to understand the bug easier, here is my blockMeshDict:
PHP Code:
/*--------------------------------*- C++ -*----------------------------------*\
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
|    \\/     M anipulation  |                                                 |
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
object      blockMeshDict;
convertToMeters 1.000000e-06;
vertices
//front
(             400               0               0 // 0 pt 4 (p4f)
(             450               0               0 // 1 pt 15 (p15f)
(             450 24.7487373415292 -24.7487373415292 // 2 pt 54 (p18b)
(             400 24.7487373415292 -24.7487373415292 // 3 pt 41 (p5b)
 //back
(             450 24.7487373415292 24.7487373415292 // 4 pt 18 (p18f)
(             400 24.7487373415292 24.7487373415292 // 5 pt 5 (p5f)
blocks
hex (0 1 2 3 0 1 4 5// i
20 7 16
simpleGrading (5 1 1// sens XYZ
edges
boundary
mergePatchPairs
I have attached a simple case with the mesh, it doesn't work of course because I don't have any patch, but you can generate and visualize the mesh.
What am I doing wrong ?? I have other blocks that have the same configuration (6 vertices, on the axis) but they are all good, I don't understand!
Paebin is offline   Reply With Quote
Old   January 13, 2014, 05:23
Fabien DOS SANTOS
I didn't mention it, but I use openFoam 2.2.2.
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
reactingMultiphaseEulerFoam tonnykz OpenFOAM Running, Solving & CFD 2 June 15, 2020 02:09
[Other] simulation of closing the gate using moving mesh simin_ds OpenFOAM Meshing & Mesh Conversion 8 April 12, 2019 05:49
Compression instead of expansion EnricoDeFilippi OpenFOAM Running, Solving & CFD 1 October 8, 2018 10:19
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
