[snappyHexMesh] SnappyHexMesh: can not generate Layers
Old   August 10, 2016, 03:17
Default SnappyHexMesh: can not generate Layers
Qianchaoqun
Qianchaoqun is on a distinguished road
Hello, gays,
I am using SHM to generate the mesh of a sedan for aerodynamics. Unfortunately a warning occurred when adding layers and this phase was skipped .
By the way, are there some requests to the stl files?
Qianchaoqun is offline   Reply With Quote
[snappyHexMesh] Controlling y+ values with snappyHexMesh? cjm OpenFOAM Meshing & Mesh Conversion 67 July 10, 2019 18:56
[snappyHexMesh] Triangular elements in boundary layers generated by snappyHexMesh mike.franky OpenFOAM Meshing & Mesh Conversion 0 June 3, 2018 09:46
[snappyHexMesh] snappyHexMesh .stl generate extra boundary gsq OpenFOAM Meshing & Mesh Conversion 0 April 21, 2018 06:03
[snappyHexMesh] SnappyHexMesh doesn't succeed in adding several layers eti0123456789 OpenFOAM Meshing & Mesh Conversion 5 April 9, 2013 02:36
[snappyHexMesh] snappyHexMesh layers part marine OpenFOAM Meshing & Mesh Conversion 7 April 27, 2010 07:09
