[blockMesh] 2:1 refined 2D blockMeshDict with mergePatchPairs?
Old   December 1, 2014, 23:52
Default 2:1 refined 2D blockMeshDict with mergePatchPairs?
Christian Butcher
chrisb2244 is on a distinguished road
I can generate a mesh if I omit the 'mergePatchPairs' section, but in that case, 'checkMesh' informs me I have x-many regions that are not connected by any faces.
If I remove duplicate vertices, I get errors relating to 'inconsistent number of faces' when running blockMesh.
When I add a 'mergePatchPairs' section, blockMesh fails. In this case, the error is given as
--> FOAM FATAL ERROR:
Face 16384 reduced to less than 3 points.  Topological/cutting error A.
Old face: 2(20622 23184) new face: 2(20622 23184)
    From function void slidingInterface::coupleInterface(polyTopoChange& ref) const
    in file slidingInterface/coupleSlidingInterface.C at line 1481.
FOAM aborting
however I have also (for similar blockMeshDict) had a error relating to a 'slicing error'.
My intention is to provide a 2:1 refined initial mesh so as to bypass difficulties with 2D AMR (since the region of interest is very simple - just the middle)
Does anyone know what I'm doing wrong? (and if there is a solution more trivial than "Go back to coding a modified fvRefineHexMesh class"?)
My blockMeshDict is as follows:
|  \\    /   O peration     | Version:  2.2.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version        2.0;
    format        ascii;
    class        dictionary;
    object        blockMeshDict;
vertices
    (0 0.0 0)
    (160.0 0.0 0)
    (160.0 11.0 0)
    (0 11.0 0)
    (0 0.0 10.0)
    (160.0 0.0 10.0)
    (160.0 11.0 10.0)
    (0 11.0 10.0)
    (0 11.0 0)
    (160.0 11.0 0)
    (160.0 11.5 0)
    (0 11.5 0)
    (0 11.0 10.0)
    (160.0 11.0 10.0)
    (160.0 11.5 10.0)
    (0 11.5 10.0)
    (0 11.5 0)
    (160.0 11.5 0)
    (160.0 11.625 0)
    (0 11.625 0)
    (0 11.5 10.0)
    (160.0 11.5 10.0)
    (160.0 11.625 10.0)
    (0 11.625 10.0)
    (0 11.625 0)
    (160.0 11.625 0)
    (160.0 16.0 0)
    (0 16.0 0)
    (0 11.625 10.0)
    (160.0 11.625 10.0)
    (160.0 16.0 10.0)
    (0 16.0 10.0)
    (0 16.0 0)
    (160.0 16.0 0)
    (160.0 24.0 0)
    (0 24.0 0)
    (0 16.0 10.0)
    (160.0 16.0 10.0)
    (160.0 24.0 10.0)
    (0 24.0 10.0)
    (0 24.0 0)
    (160.0 24.0 0)
    (160.0 28.375 0)
    (0 28.375 0)
    (0 24.0 10.0)
    (160.0 24.0 10.0)
    (160.0 28.375 10.0)
    (0 28.375 10.0)
    (0 28.375 0)
    (160.0 28.375 0)
    (160.0 28.5 0)
    (0 28.5 0)
    (0 28.375 10.0)
    (160.0 28.375 10.0)
    (160.0 28.5 10.0)
    (0 28.5 10.0)
    (0 28.5 0)
    (160.0 28.5 0)
    (160.0 29.0 0)
    (0 29.0 0)
    (0 28.5 10.0)
    (160.0 28.5 10.0)
    (160.0 29.0 10.0)
    (0 29.0 10.0)
    (0 29.0 0)
    (160.0 29.0 0)
    (160.0 40.0 0)
    (0 40.0 0)
    (0 29.0 10.0)
    (160.0 29.0 10.0)
    (160.0 40.0 10.0)
    (0 40.0 10.0)
blocks
    hex (0 1 2 3 4 5 6 7)    (320 22 1) simpleGrading (1 1 1)
    hex (8 9 10 11 12 13 14 15)    (640 2 1) simpleGrading (1 1 1)
    hex (16 17 18 19 20 21 22 23)    (1280 1 1) simpleGrading (1 1 1)
    hex (24 25 26 27 28 29 30 31)    (2560 70 1) simpleGrading (1 1 1)
    hex (32 33 34 35 36 37 38 39)    (5120 256 1) simpleGrading (1 1 1)
    hex (40 41 42 43 44 45 46 47)    (2560 70 1) simpleGrading (1 1 1)
    hex (48 49 50 51 52 53 54 55)    (1280 1 1) simpleGrading (1 1 1)
    hex (56 57 58 59 60 61 62 63)    (640 2 1) simpleGrading (1 1 1)
    hex (64 65 66 67 68 69 70 71)    (320 22 1) simpleGrading (1 1 1)
edges
boundary
    side_left
        type patch;
        faces
            (0 3 7 4)
            (8 11 15 12)
            (16 19 23 20)
            (24 27 31 28)
            (32 35 39 36)
            (40 43 47 44)
            (48 51 55 52)
            (56 59 63 60)
            (64 67 71 68)
    side_right
        type patch;
        faces
            (1 5 6 2)
            (9 13 14 10)
            (17 21 22 18)
            (25 29 30 26)
            (33 37 38 34)
            (41 45 46 42)
            (49 53 54 50)
            (57 61 62 58)
            (65 69 70 66)
    bottom
        type wall;
        faces
            (0 4 5 1)
    top
        type wall;
        faces
            (67 66 70 71)
    frontAndBack
        type empty;
        faces
            (1 0 3 2)
            (5 4 7 6)
            (9 8 11 10)
            (13 12 15 14)
            (17 16 19 18)
            (21 20 23 22)
            (25 24 27 26)
            (29 28 31 30)
            (33 32 35 34)
            (37 36 39 38)
            (41 40 43 42)
            (45 44 47 46)
            (49 48 51 50)
            (53 52 55 54)
            (57 56 59 58)
            (61 60 63 62)
            (65 64 67 66)
            (69 68 71 70)
    pm0
        type ;
        faces
            (2 6 7 3)
    ps0
        type ;
        faces
            (9 8 12 13)
    pm1
        type ;
        faces
            (10 14 15 11)
    ps1
        type ;
        faces
            (17 16 20 21)
    pm2
        type ;
        faces
            (18 22 23 19)
    ps2
        type ;
        faces
            (25 24 28 29)
    pm3
        type ;
        faces
            (26 30 31 27)
    ps3
        type ;
        faces
            (33 32 36 37)
    pm4
        type ;
        faces
            (34 38 39 35)
    ps4
        type ;
        faces
            (41 40 44 45)
    pm5
        type ;
        faces
            (42 46 47 43)
    ps5
        type ;
        faces
            (49 48 52 53)
    pm6
        type ;
        faces
            (50 54 55 51)
    ps6
        type ;
        faces
            (57 56 60 61)
    pm7
        type ;
        faces
            (58 62 63 59)
    ps7
        type ;
        faces
            (65 64 68 69)
mergePatchPairs
    ( pm0 ps0 )
    ( pm1 ps1 )
    ( pm2 ps2 )
    ( pm3 ps3 )
    ( pm4 ps4 )
    ( pm5 ps5 )
    ( pm6 ps6 )
    ( pm7 ps7 )
The blockMeshDict is generated by a python3 script.
chrisb2244 is offline   Reply With Quote
blockmesh, blockmeshdict, openfoam, openfoam-2.3
[blockMesh] mergePatchPairs problem when migrating from OFext1.6 to OFext3.1 ma-tri-x OpenFOAM Meshing & Mesh Conversion 2 January 12, 2021 04:23
[blockMesh] mergePatchPairs reducing a face to less than 3 points aow OpenFOAM Meshing & Mesh Conversion 2 June 1, 2018 17:37
2D AMR - matching faces that are not refined with refined faces chrisb2244 OpenFOAM Programming & Development 9 June 22, 2016 00:56
[blockMesh] BlockMeshDict with multiple hex blocks mergePatchPairs prousa OpenFOAM Meshing & Mesh Conversion 1 May 14, 2009 23:42
[blockMesh] MergePatchPairs in blockMeshDict lord_kossity OpenFOAM Meshing & Mesh Conversion 0 April 15, 2008 02:28
