[Commercial meshers] fluent3DMeshToFoam 'polyMesh/points' went wrong
Old   February 11, 2015, 08:12
Red face fluent3DMeshToFoam 'polyMesh/points' went wrong
deepinheart is on a distinguished road
I convert one ascii mesh file from fluent 14.5 to openfoam 2.3 and OF 3.1 ext. Everything works fine when I open it paraview. However, the generated files 'points' &'neighbour' and 'owner' can't be read and I need them for post-processing.
The msh file looks OK and just the precision of the points data is long (17) compared to the .msh file in tutorial. Will that be the problem? Even when I try to change the accepted default precision (from 10 to 20) in fluent3DMeshToFoam. It still can't be solved.
It was running well before, so I guess it comes from any update?
Have you experienced the same? Would you please help me out?
Many thanks!
deepinheart is offline   Reply With Quote
Old   February 11, 2015, 09:41
I've found it by myself. In system/controlDict, there is specified saved data in binary format. That's why it can't be seen.
Something wrong running rhoSimpleFoam (urgent!) PeterShi OpenFOAM Running, Solving & CFD 7 March 1, 2017 09:21
udf error srihari FLUENT 1 October 31, 2016 14:18
OpenFOAM command from inside MATLAB sega OpenFOAM Post-Processing 18 September 25, 2012 07:35
Wrong oriented faces due to opposite face bends? Arnoldinho OpenFOAM 5 August 16, 2012 05:00
[Commercial meshers] Fluent3DMeshToFoam - "The flipMap issue" kallakalla OpenFOAM Meshing & Mesh Conversion 0 January 4, 2012 20:23
