[snappyHexMesh] SnappyHexMesh No change of the number of cells
Old   February 12, 2009, 18:14
Default SnappyHexMesh No change of the number of cells
Christoph Spijker
christoph is on a distinguished road
Hallo everybody,
I have a problem; I want to solve a streaming about a car with the k epsilon model. At first I run the motorbike tutorial on icoFoam, and used the data as starting condition for the k epsilon model. This worked well.
I draw a car and wanted to do the same, blockmesh, snappyHexMesh run. But after this the icoFoam calculate only the 1000 cells of the blockMesh. The mesh has 137423 cells. I can see the mesh in paraView.
Any idea?
christoph is offline   Reply With Quote
Old   February 16, 2009, 03:12
Default did you move the mesh from tim
Wolfgang Heydlauff
wolle1982 will become famous soon enough
did you move the mesh from time step 3 to the constant folder? if there is a mesh inside the constant folder before (usually the blockMesh-Mesh) of ignores the Meshes in the time step folders 1, 2 and 3.
wolle1982 is offline   Reply With Quote
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 18:32
[snappyHexMesh] snappyHexMesh can't create refimenet region clktp OpenFOAM Meshing & Mesh Conversion 3 February 27, 2022 09:26
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
AMI interDyMFoam for mixer danny123 OpenFOAM Running, Solving & CFD 4 June 19, 2013 04:49
