[blockMesh] Error buffercc117assertion failed |
September 5, 2007, 03:42 |
Bernhard Blug
Hello
I get the error "buffer.cc:117:assertion failed" when executing blockmesh. The blockmeshdict is quite large (75 MB) and should generate quite a large mesh (about 500.000 elements). Is is possible to generate that large meshes with blockmesh? What do I have to alter to mesh such large meshes with blockmesh? thank you Bernhard |
September 5, 2007, 04:20 |
How did you generate such a la
Mattijs Janssens
Rep Power: 26 |
How did you generate such a large blockMeshDict file? Never seen that error before. Are your input lines extremely long?
There is no problem generating 500.000 cells as long as you have the memory. |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 15:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
