[blockMesh] mergePatchPairs master with few slaves
Like Tree7Likes
  • 1 Post By piprus
  • 6 Post By piprus
Old   March 2, 2010, 17:18
Question mergePatchPairs master with few slaves
Piotr Prusinski
piprus is on a distinguished road
Hey people,
I encountered some small problem with the mergePatchPairs and I'm eager to know how to solve it. There is a following simple situation.
Let say we have 4 hexahedrals, one of them is a base and three others are connected on top of the first one, but they don't touch each other. So in other words, there is one face of the base (mainFace) and 3 faces of those 3 blocks (face1, face2, face3) which are standing on the base. So how should I define mergePatchPairs in order to get rid of interfaces between hexes/blocks?
According to the Manual, where it's written:
There are some additional recommendations to ensure successful merge procedures:
> where a patch to be merged shares a common edge with another patch to be merged, both should be declared as a master patch.
I supposed to do it in a following manner:
mergePatchPairs
    ( mainFace face1 )
    ( mainFace face2 )
    ( mainFace face3 )
Am I right?
So what's the problem? Why I'm getting again and again the same error:
--> FOAM FATAL ERROR:
face 277 already marked for removal
    From function polyTopoChange::removeFace(const label, const label)
    in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 2807.
Sounds like my master patch disappers every time;(
Or maybe I'm wrong and it means that I suppose to cut my base at least into 3 pieces in order to connect 3 blocks? But, is it the only way?!
Maybe I should mention that I'm using OF 1.6.x.
Artur.Ant likes this.
piprus is offline   Reply With Quote
Old   March 3, 2010, 05:24
Piotr Prusinski
Ok, since I'm focused on removing interfaces from the common edge, I should care more about the "cutting tools". I mean the mergePatchPairs suppose to look like below:
mergePatchPairs
    ( face1 mainFace )
    ( face2 mainFace )
    ( face3 mainFace )
Now everything looks better from the mainFace point of view, since I want to keep it.
But there is still something wrong, because I got again the same error ;(
Old   March 3, 2010, 09:08
Thumbs up Solved
Piotr Prusinski
Ok, since nobody helps me, I came up with a simple solution. Just follow my steps:
1) The easiest way to get rid of few interfaces from one face is to put all of the faces that suppose to be removed later on in one patch - doesn't really matter whether you have one or six or even more faces to remove - I will call this patch cuttingFaces.
2) Then you have to define a patch, let say mainFace, which should stay after all.
3) Since you've done it you have to now define mergePatchPairs like below
mergePatchPairs
    ( cuttingFaces mainFace )
And that's all
If you find some problems with it, it means likely that your grid is not enough dense.
Old   November 8, 2012, 09:32
Unnikrishnan Mohankumar
unnikrsn is on a distinguished road
Thanks for your tip..
It is very helpful..
unnikrsn is offline   Reply With Quote
face, master, mergepatchpairs, slave
big difference between clockTime and executionTime LM4112 OpenFOAM Running, Solving & CFD 21 February 15, 2019 03:05
foam-extend-3.2 Pstream: "MPI_ABORT was invoked" craven.brent OpenFOAM Running, Solving & CFD 5 November 18, 2015 07:55
Compilation error with OpenFOAM 2.1.x Martin_ OpenFOAM Installation 28 January 15, 2013 06:58
openfoam 1.6 on debian etch romant OpenFOAM Installation 9 May 6, 2010 02:26
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
