[blockMesh] 90 degrees pipe bend - changing shape midway
Old   May 20, 2010, 11:25
Default 90 degrees pipe bend - changing shape midway
kjetil is on a distinguished road
Dear foamers,
I have created a bend in blockMesh using the O-grid technique (squared center section). However, when investigating the 3D geometry in paraView, the mid pipe profile (45 degrees) of the bend is not quite circular. I have looked over the arc section in blockMeshDict over and over again, but I cannot find any obvious errors. It this how it is supposed to be, or should I file a bug report?
kjetil is offline   Reply With Quote
Old   May 25, 2010, 02:29
Lachlan Graham
Locky3827 is on a distinguished road
I have had a similar experience with a pipe bend geometry, I could not find anything to explain it.
I used Solidworks to check the numbers used on the arcs, could not fix the problem.
Lachlan
Locky3827 is offline   Reply With Quote
Old   May 25, 2010, 04:16
Good. A temporary solution in blockMesh may be to create pipe bend in increments of, say ~40 degrees. Apart from that, an external mesh/geometry seems to be the only way out at the moment.
I have now also filed a "bug report" using a 179.9 degree bend (-> http://www.cfd-online.com/Forums/ope...rved-bend.html).
Old   May 25, 2010, 20:07
Lachlan Graham
Many thanks for that. I was also going to try the simple if tedious option of increments. I will also have a go with ExtrudeMesh as in the bug report.
Regards,
Lachlan
need help about double pipe heat exchanger with chtMultiRegionSimpleFoam wuyangzhen OpenFOAM 10 December 12, 2017 00:19
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 18:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 07:18
How to get "Fully developed flow" at pipe inlet without changing length nihossain FLUENT 0 November 2, 2011 16:22
changing Mesh with known new points for shape kilerskill OpenFOAM 15 February 16, 2011 03:21
