[blockMesh] Pyramid using BlockMesh
Old   November 9, 2010, 12:33
Default Pyramid using BlockMesh
ramhari is on a distinguished road
I want to mesh a pyramid shape...i am running the following blockMeshDict file but i am getting segmentation fault...can anyone help me !
| \\ / O peration | Version: 1.7.0 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0) //0
(1 0 0) //1
(1 1 0) //2
(0 1 0) //3
(0.5 0.5 0.5) //4
blocks
pyr 5(0 1 2 3 4) (10 10 10) simpleGrading (1 1 1)
edges
patches
mergePatchPairs
Output :
Creating block mesh from
"/home/hariram/Desktop/cone/constant/polyMesh/blockMeshDict"
Creating blockCorners
Creating curved edges
Creating blocks
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
in "/opt/openfoam171/applications/bin/linuxGccDPOpt/blockMesh"
#8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Segmentation fault
ramhari is offline   Reply With Quote
Old   November 15, 2010, 12:50
Default Re : pyramid
I could do that using 'hex' keyword with 5 vertices instead of using 'pyr'.
Thanx, Hari
Old   February 14, 2012, 11:02
gimmetwofingers is on a distinguished road
I am also looking for a way to produce a pyramid in blockMesh. However for me it does not work to use the hex keyword with five entries. I also tried
hex (0 1 2 3 4 4 4 4)
However that also did not work. How can I get a nice pyramid?
Thanks!
gimmetwofingers is offline   Reply With Quote
Old   July 18, 2012, 14:57
Nikunj Raithatha
Nikunj.R is on a distinguished road
just use 01234
Nikunj.R is offline   Reply With Quote
Old   February 5, 2017, 14:47
Mehdi
mehdiataei is on a distinguished road
Could anyone fix it? I cannot create a pyramid neither with hex nor with pyr and I don't get why
vertices
(1 -0.0436 0.0436)
(1 0.0436 0.0436)
(1 0.0436 -0.0436)
(1 -0.0436 -0.0436)
(0 0 0)
blocks
pyr (0 1 2 3 4) (50 1 1) simpleGrading (1 1 1)
mehdiataei is offline   Reply With Quote
Old   February 5, 2017, 20:10
Antimony is on a distinguished road
For your given set of vertices, have you tried this?
hex (0 1 2 3 4 4 4 4) (nx ny nz) simpleGrading (s1 s2 s3)
where nx, ny, nz, s1, s2, s3 are all values that you want to input.
Cheers,
Antimony
Antimony is offline   Reply With Quote
blockmesh, cone, pyramid
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
