[snappyHexMesh] SHM add layers problem
Old   June 6, 2011, 12:01
Default SHM add layers problem
doubtsincfd is on a distinguished road
Why is the mesh different when I run "addLayers false" as a first case and "addLayers true" but with nSurfaceLayers = 0. The difference can be noticed in the SHM log. When addLayers is true, it runs some additional mesh quality checks and somehow it distorts the mesh. Why is there a difference in the two cases?
doubtsincfd is offline   Reply With Quote
[snappyHexMesh] Add Layers in snappyHexMesh shchepan OpenFOAM Meshing & Mesh Conversion 24 May 14, 2020 12:29
[snappyHexMesh] problem with snappyHexMesh:fail to add Boundary Layers gogo OpenFOAM Meshing & Mesh Conversion 0 January 7, 2019 03:23
[snappyHexMesh] Old and busted: snappyHexMesh and add layers with edges Siassei OpenFOAM Meshing & Mesh Conversion 6 August 14, 2018 18:33
[snappyHexMesh] snappyHexMesh: How to add layers to part of an STL? Dreoasteh OpenFOAM Meshing & Mesh Conversion 0 May 14, 2018 10:59
[snappyHexMesh] SHM no layers added student666 OpenFOAM Meshing & Mesh Conversion 7 May 15, 2014 05:51
