[blockMesh] Specifying the height of the first cell of a block using simpleGrading
Old   June 16, 2011, 13:15
Default Specifying the height of the first cell of a block using simpleGrading
Alex
bigbang is on a distinguished road
Has anybody come up with a formula to solve the ratio you need for a given first layer height and total block height in blockMesh?
Example:
Let's say I'm modeling the flow over a thin plate 4m long as a single block. I want my first layer of cells on the plate to be 0.001m in height. Outside of using multiple blocks, can I specify a certain expansion ratio for a given block height that will give me exactly 0.001m in height on the first layer?
bigbang is offline   Reply With Quote
Old   June 16, 2011, 13:52
Alex
Nevermind. I found a program that does it in the same forum...
http://www.cfd-online.com/Forums/ope...alculator.html
[blockMesh] --> FOAM FATAL ERROR: Trying to specify a boundary face A.A. OpenFOAM Meshing & Mesh Conversion 41 June 26, 2020 07:06
[blockMesh] edges not aligned with or perpendicular to non-empty directions ynos OpenFOAM Meshing & Mesh Conversion 6 March 26, 2020 15:02
[blockMesh] Openfoam: Meshing, where do my defaultFaces come from syntex OpenFOAM Meshing & Mesh Conversion 19 December 10, 2018 07:21
Neighboring cells in tetrahedral mesh vishwesh OpenFOAM Programming & Development 9 November 10, 2017 07:06
[blockMesh] FOAM FATAL ERROR: face 0 in patch 0 does not have neighbour cell face am9109 OpenFOAM Meshing & Mesh Conversion 41 October 15, 2015 03:59
