[blockMesh] Problem with Mesh Volume
Old   January 29, 2012, 10:01
Default Problem with Mesh Volume
seboxx is on a distinguished road
Dear Foamers,
I am struggling with a Problem for several weeks already and starting to get really desperate. I have posted it in the main forum already, but I figured posting a new thread here as I have narrowed the problem down to blockMesh, I guess so at least.
The Problem is I want to simulate a thin layer with a bump, I have modelled the bump with a blockMeshDict.
What is wrong here is that the volume is not recognized correctly. You can see in checkMesh the total volume of 1256.62. But this cannot be correct, since a flat disc with height one and radius 20 would have exactly that volume (Pi*r^2)
But the graphical output in paraview is correct. Whats wrong here?
Now when I do checkMesh, this is the output
|  \\    /   O peration     | Version:  2.0.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 2.0.0-a317a4e7cd55
Exec   : checkMesh
Date   : Jan 29 2012
Time   : 15:48:06
Host   : ernie
PID    : 7269
Case   : /home/boie/OpenFOAM/OpenFOAM-reloaded/boie-2.0.0/simulations/tests/justbump
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    internal points:  0
    faces:            160400
    internal faces:   79600
    cells:            40000
    boundary patches: 3
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     40000
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    frontWall           40000    40401    ok (non-closed singly connected)
    backWall            40000    40401    ok (non-closed singly connected)
    circular            800      1600     ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-20 -20 -0.0312941) (20 20 21)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (8.25305e-21 7.15265e-20 -3.39808e-19) OK.
    Max cell openness = 2.24782e-16 OK.
    Max aspect ratio = 321.104 OK.
    Minumum face area = 0.000702619. Maximum face area = 0.283752.  Face area magnitudes OK.
    Min volume = 0.000692074. Max volume = 0.0803204.  Total volume = 1256.62.  Cell volumes OK.
    Mesh non-orthogonality Max: 87.5911 average: 38.3172
   *Number of severely non-orthogonal faces: 624.
    Non-orthogonality check OK.
  <<Writing 624 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
    Max skewness = 2.81207 OK.
Mesh OK.
End
seboxx is offline   Reply With Quote
Old   January 30, 2012, 03:17
BastiL
bastil is on a distinguished road
I don't see you problem. Your formula is right and I get:
3.14*20^2=3.14*400=1256.
So for me everything seems to be fine.
bastil is offline   Reply With Quote
Old   January 30, 2012, 03:21
Hi bastil,
well the problem is the volume must be larger than this.
See the attached picture, its a bump and not a disc anymore. The Problem is similiar to taking a cube and a cube with a large dent in it but with the same length of the edges. The volume should be different
Old   January 30, 2012, 08:19
To illustrate my problem I have made 2 more screenshots. In the first picture you look from on top on the geometry.
In the second picture is the same geometry with a different angle of observation. checkMesh reports no errors and a total volume of:
Total volume = 400.
But that is the volume like if i project the geometry into the xy-plane.
On the second picture you see the real geometry and clearly the volume must be larger...
I really have no idea what is going wrong here
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
Ansys 12 Workbench problem when generating volume mesh Sveink ANSYS 5 January 6, 2010 03:17
