April 12, 2012, 07:15 |
multiregion mesh with blockMesh
Alpesh
Rep Power: 15 |
Hello friends,
I am using chtmultiregion solver for my problem.. I want to mesh a sphere inside a cube.. I want to define the sphere as solid region and surrounding area as fluid region.. I don't know that how to define interface patch boundary in blockMesh.. Is there any way to split blockMesh mesh? I made a blockMeshDict for sphere inside the cube.. I ran blockMesh command and got mesh.. But now How I can define spherical part as separate region? Regards Alpesh |
May 1, 2012, 05:37 |
Hello Alpesh,
I think, you need to define your sphere as wall type. with regards, Sivakumar |
May 1, 2012, 10:12 |
Sounds like a nice - but possible! - challenge you are looking at!
Maybe there have been major changes, but to my knowledge you have to define the different regions via another dictionary file, not via blockMesh. The blockMeshDict is there to define the mesh. Another file is there for setting up the different regions. If you look at the tutorial case for chtMultiRegionFoam (for example $FOAM_TUTORIALS/heatTransfer/chtMultiRegionFoam/multiRegionHeater ) you will find that there is a file called makeCellSets.setSet. This is the file where the different regions are defined. For a basic understanding you might look into https://blinseis.web.cern.ch/blinsei...RegionFoam.pdf . I really have to review this howTo, but it describes a bit of setting up a basic case for chtMultiRegionFoam, including few explanations concerning the *.setSet file. Unfortunately I do not know anything about round structures in setSet. So it would be great if you could share your experiences with that afterwards! ;-) Hope this helps a bit... |
May 1, 2012, 11:10 |
Martin
Rep Power: 21 |
Hi all,
it is possible to split a blockMesh mesh into several regions. Give the blocks the names of the regions like this: Code:
hex (0 1 3 2 6 7 9 8) name_of_region_1 (200 100 1) simpleGrading (1.0 1.0 1.0) hex (2 3 5 4 8 9 11 10) name_of_region_2 (200 100 1) simpleGrading (1.0 1.0 1.0) Code:
splitMeshRegions -cellZones -overwrite Martin |
May 1, 2012, 11:41 |
#5 | |
Just by chance: Do you know if these regions then are equal to the regions one would produce via the tutorial-way? I.e., does it replace the *.setSet-file? |
May 1, 2012, 11:59 |
Martin
Rep Power: 21 |
Hi Bernhard,
yes, you don't need to have *.setSet files anymore. Martin |
May 6, 2012, 12:42 |
#7 | |
Alpesh
Rep Power: 15 |
Thanx for your reply.. I need mesh inside the sphere also.. because I want to investigate inside the sphere also.. hence, I cannot treat as a only wall solid... Kind regards Alpesh |
May 6, 2012, 12:58 |
#8 | |
Alpesh
Rep Power: 15 |
Thanx for you information and link.. I also tried with spherToCell cellSet function in .setSet dictionary.. But, it didn't generate perfect sphere (surface of sphere was zigzag..it was not smooth).. I think, because sphereToCell consider all cell centers in given redius, not the facecenters.. Kind Regards Alpesh |
May 6, 2012, 13:18 |
#9 | |
Alpesh
Rep Power: 15 |
Hello Martin, thank you very much.. I was not aware that how to define different regions in blockMesh dictionary.. so, I made with Gambit and it worked fine.. But, Now, I think I can make it with blockMesh.. I was not aware that we can define region name this way... Thank you very much once again... I will make and I will reply.. Kind Regards Alpesh |
June 5, 2012, 09:16 |
#10 |
namdar
Rep Power: 14 |
Hi All
I want change the " makecellsets.setset " for my problem. What is the numbers in bracket in this file ? Introduce a reference for How change this file. thanks for your attention. |
June 8, 2012, 09:31 |
#11 |
Hi Budlo,
basically, the numbers in the makeCellSets.setSet tell about the dimensions of the different cells/regions. Usually they are the minimal and the maximal values for a rectangular zone. So if there is (0 0 0)(2 3 1) that would describe a box opened between points (0 0 0) and (2 3 1). And as Martin mentioned the tutorial helped, I do not fear suggesting reading it as well! (see link few entries above) |
June 9, 2012, 06:11 |
#12 |
namdar
Rep Power: 14 |
Hi Linse
Thanks for your reply. I know this note but see the example of solver in MultiRegionHeater. In this example we have a rectangular (LeftSolid) which minimum x of that is ((-0.1m)) and maximum x is ((-0.01333m)) in "controlMeshDict" but in makeCellSets.setSet write : (-100 miny minz ) (-0.01 maxy maxz) . Why are they different ? |
June 22, 2012, 06:07 |
#13 |
Well, I guess there is no real reason for the numbers being different. I would guess that the region zones just have to include the whole mesh zone. So I GUESS the values were kind of chosen out of the blue, just for being big enough...
Of course, anybody knowing more about that point is welcome to correct me! ;-) |
June 23, 2012, 06:21 |
#14 |
namdar
Rep Power: 14 |
Hi dear Bernhard
Bernhard : { Just by chance: Do you know if these regions then are equal to the regions one would produce via the tutorial-way? I.e., does it replace the *.setSet-file? } Does This reply means that with "splitMeshRegions -cellZones -overwrite " after creat blockMeshDic then we dont need creat MakeCellSet.setSet ? Thanks a lot. |
June 23, 2012, 06:28 |
#15 |
namdar
Rep Power: 14 |
Hi Martin
What do you think about the example of solver in MultiRegionHeater ? In this example we have a rectangular (LeftSolid) which minimum x of that is ((-0.1m)) and maximum x is ((-0.01333m)) in "controlMeshDict" but in makeCellSets.setSet write : (-100 miny minz ) (-0.01 maxy maxz) . Why are they different ? Does your above massage means that with "splitMeshRegions -cellZones -overwrite " after creat blockMeshDic then we dont need creat MakeCellSet.setSet ? Best Regards |
June 23, 2012, 09:12 |
#16 | |
Martin
Rep Power: 21 |
I think you don't need the makeCellSets.setSet file at all, at least in OpenFOAM-2.1.x. It might be a leftover from previous versions, or may be it's necessary in the Extend version. Just delete the file and run the fresh tutorial case again, I suppose it's running fine. All important stuff is defined in system/topoSetDict. Quote:
Indeed the usage of makeCellSets.setSet or the topoSetDict file is just an example for a meshing strategy that is independent from conjugate heat transfer. I.e. if you have a really simple formed computational domain consisting of blocks you can use this special meshing strategy to divide a simple block shaped mesh into several parts. On the other side if you build up your mesh in another way (multiple mesh regions in a commercial mesher, a more sophisticated blockMeshDict in combination with the "-cellZones" option, or whatever strategy you like), you can still use the conjugate heat transfer solvers and without any makeCellSets.setSet or topoSetDict file. May be you can post a sketch of your geometry so that I can give advice on the appropriate blockMesh definition... CU Martin |
June 24, 2012, 03:38 |
#17 |
namdar
Rep Power: 14 |
Martin :
May be you can post a sketch of your geometry so that I can give advice on the appropriate blockMesh definition... Martin. Hi Martin thanks a lot for your complete explain. I want simulate a flow over a solid that solid has conduction in "MultiRegionHeater". the boundary between them is conjugate . I do this procceger : 1- Make mesh in Gambit and set two region,solid and fluid, with "Internal" boundary condition at conjugate boundary same the example of solver. 2- code : runApplication fluentMeshToFoam Mymesh.msh -writeSets 3- code : runApplication setsToZones -noFlipMap 4- code : runApplication splitMeshRegion -cellZones -overwrite 5- Remove extra boundary condition in each region at 0 file (Its code is in Allrun). 5- Creat all files, boundary condition and changeDictionaryDict. 6- Make log.changeDEctionaryDic (Its code is in Allrun) 7- code : chtMultiRegionFoam It is work for free convection but for force convection divergence. Best Regards Last edited by Budlo; June 27, 2012 at 08:19. |
July 25, 2012, 08:59 |
#18 |
Per Nilsson
Rep Power: 17 |
I would like to take the region creation one step further using blockMesh.
How can multiple hex-blocks be added to the same cellSet within blockMesh? In the example given by MartinB, there is only one hex-block in each cellSet created by blockMesh. I would like to have three connected hex-blocks in the same cellSet created by blockMesh, thus avoiding the need to join them with e.g. setSet, before running splitMeshRegions. Best regards |
July 25, 2012, 09:02 |
#19 |
Martin
Rep Power: 21 |
Hi Per,
just give the blocks the same name: hex (0 1 3 2 6 7 9 8) name_of_region_1 (200 100 1) simpleGrading (1.0 1.0 1.0) hex (2 3 5 4 8 9 11 10) name_of_region_1 (200 100 1) simpleGrading (1.0 1.0 1.0) Now the two blocks form one region. You can add more blocks, of course. Martin |
August 16, 2012, 08:44 |
Problems to run BlockMesh
#20 |
Paula
Rep Power: 13 |
I´m reading the tutorial Linse talked about ( https://blinseis.web.cern.ch/blinsei...RegionFoam.pdf .) and I´m having some problems to run it. I´ve created the files as I´ve read, but when I enter the command blockMesh, it appears the error message: cannot open mesh description fil "/home/termico/OpenFOAM/Paula-2.1.0/FOAM_RUN/MultiBlock/constant/polyMesh/BlockMeshDict" From function blockMesh in file blockMeshApp.c at line 148 What´s the problem? Thanks! |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 16:59 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
