[Gmsh] Thin walls (baffles) inside volume with Gmsh
Old   November 15, 2012, 09:41
Default Thin walls (baffles) inside volume with Gmsh
styleworker is on a distinguished road
I'm trying to implement baffles in my geometry in gmsh. If I run gmshToFoam without baffles, it works well. But if I implement the baffles, I'll get several warnings like (face 4=baffles):
--> FOAM Warning : Not using gmsh face 4(26644 3547 161 3530) since zero vertex is not on boundary of polyMesh
I've also tried to define each volume between the baffles, but I didn't help.
Does anybody have an idea?
kind regards
styleworker is offline   Reply With Quote
Old   November 20, 2012, 09:32
I've solved the problem. For instructions, see miles_davis post: http://www.cfd-online.com/Forums/ope...tml#post323464 (it works also for gmshToFoam)
Distance between walls with thin wall/shell conduction mir9283 FLUENT 0 May 16, 2018 03:49
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 10:44
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
[Commercial meshers] Thin Walls Conversion from Fluent Mesh Isaac OpenFOAM Meshing & Mesh Conversion 1 March 4, 2016 12:08
