[Netgen] problems with all dates from polymesh,after use ideastoFoam...
Old   May 8, 2013, 03:24
Default problems with all dates from polymesh,after use ideastoFoam...
anna-laura virgili
virgili is on a distinguished road
Good morning!
I am a student, i need to write my thesis about a interaction between a structure and the wind! so i though that is a good idea, make a mesh with salome and then use Openfoam! my problem is that when a export the mesh to .unv all its running, also "ideastoFoam", and chekmesh says that everything iis ok...but when i open the "point","bounday" "faces"....all created with "ideastoFoam" from "mymesh.unv" i find only this!!
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
0
Nothing is inside! :-/ whats happens?
i am using "netgen 3d-1d-2d", because its a 3d structure like a membrane, and i think it is a good algorithm to mesh, am i right??
thank very much for your help!
virgili is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 03:45
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
unstructured grid sreekanth Main CFD Forum 1 August 6, 2001 15:09
Inverse problems Aleksey Alekseev Main CFD Forum 0 May 12, 1999 15:38
