[mesh manipulation] splitMesh utility
Old   January 4, 2014, 05:47
Default splitMesh utility
achyutan is on a distinguished road
I would like to use an internal surface as a boundary surface and apply b.c on the same.
Could someone explain to me how to use splitMesh utility ? what are the things to be set prior to running the utility ?
Any tutorial that uses splitMesh ?
thanks,
achyutan is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
Noise postprocessing utility setup RFlamm OpenFOAM Post-Processing 5 July 30, 2018 10:06
wallHeatFlux Calculation wrt utility version ahmet OpenFOAM Post-Processing 1 December 18, 2016 19:45
[mesh manipulation] mirrorMesh utility preserving regions zfaraday OpenFOAM Meshing & Mesh Conversion 1 November 7, 2016 21:51
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! zfaraday OpenFOAM Post-Processing 0 February 5, 2015 16:47
