[Other] surfaceFeatureExtract Issue
Old   May 7, 2015, 16:10
Default surfaceFeatureExtract Issue
Joshua Hinton
jhint9 is on a distinguished road
Hey all,
I'm still new to OpenFOAM, and am having an issue with the surfaceFeatureExtract command before I get into snappyHexMesh. I am modelling a propeller with 10 blades inside of a domain that has already been created with blockMesh. I have 13 total .stl files for the propeller created with SolidWorks, 10 of them being individual blades. surfaceFeatureExtract works just fine with 7 of the blades and the remaining 3 files I have. However, it gives an error for blades 3,4 & 7. I included that error for blade 3. I logged each of the outputs and I have noticed that a difference is "region edges." For the successful files it states "region edges : 0" while the failed files state "region edges : 4." I also attached a log for both a successful file (logblade1) and failed file (logblade3). I'm a little confused as the blades are all copies of one another. I'm not exactly sure what these mean or if that even is the exact issue, but any help and any ideas are appreciated! Thanks!
jhint9 is offline   Reply With Quote
Old   May 13, 2015, 14:41
roadRunner is on a distinguished road
Are you sure you need to use surfaceFeatureExtract? Can't you use .stl-s directly, without extracting features?
Also, did you try to check .stl quality? You can do this with surfaceCheck, or third-party software, I suggest Netgen.
beep-beep
roadRunner is offline   Reply With Quote
Old   May 14, 2015, 13:07
Joshua Hinton
I was actually able to get it to work by taking out the mates in SolidWorks before saving the .stl files. For some reason I guess surfaceFeatureExtract doesn't like the mates. But all I need is the geometry anyway so it shouldn't really matter. I'll definitely check using surfaceCheck and see what I can do with Netgen. Thanks for the advice!
snappyhexmesh, surfacefeatureextract, surfacefeatureextraction
CAMWA special issue on open-source numerical solver feixu2019 OpenFOAM Announcements from Other Sources 0 October 1, 2018 11:21
CAMWA special issue on open-source numerical solver feixu2019 SU2 News & Announcements 0 October 1, 2018 11:19
Strange issue while launching ANSYS workbench in CentOS 6.4 Philip_C ANSYS 11 August 29, 2013 06:44
CyclicAMI Issue In OpenFOAM 2.2.0 prasant OpenFOAM Running, Solving & CFD 17 March 16, 2013 02:00
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 08:27
