[Gmsh] Basic Question-defaultFaces
Old   June 16, 2015, 20:54
Default Basic Question-defaultFaces
vito
vitocorleone is on a distinguished road
Hello Everyone,
I am new to gmsh and openfoam. I have a simple channel in gmsh and meshed it. I am trying to do a 2d simulation in openfoam and I am trying to do this by setting the boundary condition to "empty" for the faces in the 3rd dimension. I went through the previous posts and found that gmsh puts all faces in the default Faces and hence the following warning can be ignored.
FOAM Warning :
From function polyMesh:olyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 627
Found 6484 undefined faces in mesh; adding to default patch.
check mesh says mesh is ok
But when i try to run icoFoam I get the following error
Cannot find patchField entry for defaultFace
What boundary conditions ( as in P and U and boundary file )should I use for the default faces ?? Also when i try to visualize this in paraview I don't see anything. Looking forward to some help .
Thank you
vitocorleone is offline   Reply With Quote
Old   June 17, 2015, 03:33
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Did you define physical groups in your Gmsh mesh (they become OpenFOAM's patches after conversion)?
Do you use foam-extend? There gmshToFoam does not delete empty defaultFaces patch after conversion. So you should set type of the patch to empty in constant/polyMesh/boundary dictionary and use empty type in IC/BC (i.e. 0/*) files.
alexeym is offline   Reply With Quote
Old   June 21, 2015, 16:35
vito
Alexym,
Thank you for your time and reply. I have defined the physical groups in gmesh. I am not using foam extend. Also I believe I still need to do my homework and background work when it comes to defining boundary conditions.
Will post more relevant questions when I have them.
Thanks once again
Basic Fluent Statistics Question amanbearpig FLUENT 2 June 4, 2013 05:36
[Other] very basic question about createPhi.H feldy77 OpenFOAM Meshing & Mesh Conversion 2 November 22, 2011 08:16
Basic question to buoyantBoussinesqPisoFoam kriz OpenFOAM 2 June 12, 2010 03:35
Basic Question Abhi FLUENT 1 August 4, 2007 08:07
Basic question: UDF for wall heat flux Carl FLUENT 1 August 5, 2006 19:01
