[snappyHexMesh] Collapsing Layers
Like Tree2Likes
  • 1 Post By danielpiaget
Old   July 10, 2015, 12:17
Default Collapsing Layers
Tim
Tim_Simon is on a distinguished road
Hey everyone!
I'm currently working on a simulation of the wind flow over a suburban area. The simulation domain consists of a bigger lake with some islands in it. Of course I want to add layer to the ground surface. But as you can see in the attached images, layers are collapsing.
Now I already tried to modify the featureAngle setting but without success. I also tried the solution given in this thread. But the changeDirectory method hasn't worked as well.
I attached a second image showing the surface mesh of the ground surface and now I wonder if those cells are the reason for the layers to collapse. I am not that experienced with snappy so I would be more than happy for an advise or two
Quick second question: I have several .stl files for the forests in the computed area. I am going to write those areas to cellZones. So that I can later define them as a porous medium. Now if I mesh them relatively coarse in the refinement process, will the layer generation again look for those forest-defining stl's and refine the inside or not? Or are the layers even overriding the cellZones?
Thanks in advance,
Tim
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh false;
snap            false;
addLayers       true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    domain.stl
        type triSurfaceMesh;
        name domain;
        sueden
        type searchablePlane;
        planeType pointAndNormal;
        pointAndNormalDict
                basePoint (372424 5808836 0);
                normalVector (0 -1 0);
    osten
        pointAndNormalDict
                basePoint (377998 5808836 0);
                normalVector (1 0 0);
    norden
        pointAndNormalDict
                basePoint (372424 5813998 0);
                normalVector (0 1 0);
    westen
        pointAndNormalDict
                normalVector (-1 0 0);
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 20000000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 20000000;
    // The surface refinement loop might spend lots of iterations refining just a
    // few cells. This setting will cause refinement to stop if <= minimumRefine
    // are selected for refinement. Note: it will at least do one iteration
    // (unless the number of cells to refine is 0)
    minRefinementCells 5;
    // Allow a certain level of imbalance during refining
    // (since balancing is quite expensive)
    // Expressed as fraction of perfect balance (= overall number of cells /
    // nProcs). 0=balance always.
    maxLoadUnbalance 0.10;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 3;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
    domain
        level (2 2);
    // Resolve sharp angles
    resolveFeatureAngle 30;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    locationInMesh (374001.1 5812001.1 149.9);
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 5;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    tolerance 4.0;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 40;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 10;
    // Feature snapping
        //- Number of feature edge snapping iterations.
        //  Leave out altogether to disable.
        nFeatureSnapIter 30;
        //- Detect (geometric only) features by sampling the surface
        //  (default=false).
        implicitFeatureSnap true;
        //- Use castellatedMeshControls::features (default = true)
        explicitFeatureSnap true;
        //- Detect points on multiple surfaces (only for explicitFeatureSnap)
        multiRegionFeatureSnap false;
// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
    // Per final patch (so not geometry!) the layer information
    layers
        domain
            nSurfaceLayers 5;
    locationInMesh (374001.1 5810001.1 299.9);
snapControls
    //  to surface
    nSmoothPatch 5;
    tolerance 4.0;
    nSolveIter 40;
    nRelaxIter 10;
    // Feature snapping
        //  (default=false).
    // Expansion factor for layer mesh
    expansionRatio 1.2;
    // Wanted thickness of final added cell layer. If multiple layers
    // is the
    // thickness of the layer furthest away from the wall.
    // Relative to undistorted size of cell outside layer.
    // is the thickness of the layer furthest away from the wall.
    // See relativeSizes parameter.
    finalLayerThickness 0.8;
    // Minimum thickness of cell layer. If for any reason layer
    // cannot be above minThickness do not add layer.
    minThickness 0.001;
    // If points get not extruded do nGrow layers of connected faces that are
    // also not grown. This helps convergence of the layer addition process
    // close to features.
    // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
    nGrow 1;
    // Advanced settings
    // When not to extrude surface. 0 is flat surface, 90 is when two faces
    // are perpendicular
    featureAngle 180;
    // At non-patched sides allow mesh to slip if extrusion direction makes
    // angle larger than slipFeatureAngle.
    slipFeatureAngle 30;
    // Maximum number of snapping relaxation iterations. Should stop
    nRelaxIter 3;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 1;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 3;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 1.0;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 1.0;
    // Angle used to pick up medial axis points
    // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
    minMedianAxisAngle 130;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    //- Maximum non-orthogonality allowed. Set to 180 to disable.
    maxNonOrtho 65;
    //- Max skewness allowed. Set to <0 to disable.
    maxBoundarySkewness 10;
    maxInternalSkewness 2;
    //- Max concaveness allowed. Is angle (in degrees) below which concavity
    //  is allowed. 0 is straight face, <0 would be convex face.
    //  Set to 180 to disable.
    maxConcave 80;
    //- Minimum pyramid volume. Is absolute volume of cell pyramid.
    //  Set to a sensible fraction of the smallest cell volume expected.
    //  Set to very negative number (e.g. -1E30) to disable.
    minVol 1e-13;
    //- Minimum quality of the tet formed by the face-centre
    //  and variable base point minimum decomposition triangles and
    //  the cell centre. This has to be a positive number for tracking
    //  to work. Set to very negative number (e.g. -1E30) to
    //  disable.
    //     <0 = inside out tet,
    //      0 = flat tet
    //      1 = regular tet
    minTetQuality 1e-30;
    //- Minimum face area. Set to <0 to disable.
    minArea -1;
    //- Minimum face twist. Set to <-1 to disable. dot product of face normal
    //- and face centre triangles normal
    minTwist 0.02;
    //- minimum normalised cell determinant
    //- 1 = hex, <= 0 = folded or flattened illegal cell
    minDeterminant 0.001;
    //- minFaceWeight (0 -> 0.5)
    minFaceWeight 0.02;
    //- minVolRatio (0 -> 1)
    minVolRatio 0.01;
    //must be >0 for Fluent compatibility
    minTriangleTwist -1;
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 4;
    //- amount to scale back displacement at error points
    errorReduction 0.75;
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
Tim_Simon is offline   Reply With Quote
Old   July 13, 2015, 09:01
DanielP
danielpiaget is on a distinguished road
Hello Tim,
I notice that certains parameters that should be under the AddLayerControls dictionary are defined outside the dictionary. See below the parameters that should be moved. I have modified the sub-dictionary for AddLayersControls.
__________________________________________________ ___
addLayersControls
relativeSizes true;
layers
domain
nSurfaceLayers 5;
expansionRatio 1.2;
// is the
minThickness 0.001;
nGrow 1;
featureAngle 180;
nRelaxIter 3;
nSmoothNormals 3;
// mesh.
nLayerIter 50;
danielpiaget is offline   Reply With Quote
Old   July 13, 2015, 14:15
Tim
Hello Daniel,
thank you for your reply. I fixed the snappyHexMeshDict. Don't know how this happenend. The layer generation does work better now but unfortunatley layers are still collapsing over the domain. I have attached several images showing some of the problematic areas.
I'm trying my best to find parameters that suit my surface but to this point without success. It seems that the slightest change of topography (heights or depths) is causing massive trouble.
Kind regards,
Tim
|  \\    /   O peration     | Version:  2.4.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
castellatedMesh true;
snap            true;
addLayers       true;
geometry
    domain.stl
        name domain;
    maxLocalCells 100000;
    maxGlobalCells 2000000;
    minRefinementCells 10;
    // refinement.
    nCellsBetweenLevels 10;
    features
    refinementSurfaces
        domain
            // Surface-wise min and max refinement level
            level (2 2);
    // three modes
    refinementRegions
    // Mesh selection
    locationInMesh (374001.1 5812001.1 199.1);
snapControls
    //  to surface
    nSmoothPatch 3;
    tolerance 2.0;
    nSolveIter 30;
    nRelaxIter 5;
    // Feature snapping
        nFeatureSnapIter 10;
        //  (default=false).
        implicitFeatureSnap false;
addLayersControls
    relativeSizes true;
    layers
        domain
            nSurfaceLayers 12;
    expansionRatio 1.2;
    finalLayerThickness 0.5;
    minThickness 0.001;
    nGrow 0;
    featureAngle 180;
    nRelaxIter 30;
    nSmoothSurfaceNormals 10;
    nSmoothNormals 30;
    nSmoothThickness 50;
    maxFaceThicknessRatio 1;
    maxThicknessToMedialRatio 1;
    minMedianAxisAngle 90;
    // mesh.
    nLayerIter 50;
// where to undo.
meshQualityControls
    #include "meshQualityDict"
    // Advanced
    nSmoothScale 4;
// Advanced
// Write flags
writeFlags
    scalarLevels
    layerSets
    layerFields     // write volScalarField for layer coverage
Old   July 13, 2015, 21:40
DanielP
Hello Tim,
Regarding the boundary layers parameters.Note the following :
-relativeSizes: This parameter will control the finalLayerThickness parameter. By setting it to true, the finalLayerThickness is divided by the length of the patch, in other words the last boundary layer will be 0.5/patch lenght and not 0.5.
-To calculate a reasonable finalLayerThickness, take the length of one cubic element from your blockMesh mesh and divide by 2 power (refinement) or
length/2^2. This will give you an estimation of the length of the Snap mesh individual element. Take a percentage of this length (10-15%).
-Try lowering your expansionRatio to 1.00-1.08.
-The minMedianAxisAngle since very high. Try a lower angle, see 5 degree.
This will control the extrusion of the boundary layer when the Snap mesh is translated towards the center.
Also, try to generate 1 perfect boundary layer.
This link might be also useful:
http://www.openfoamwiki.net/index.php/SnappyHexMesh
Thanks,
Daniel
dickcruz likes this.
Old   July 29, 2015, 10:16
Tim
Hey Daniel, thanks again for your help.
As I understand the finalLayerThickness refers to the already refined cell size on that specific surface and not the initial cell size of blockMesh?
I have looked up the snappy tutorials you linked for me. I am currently using the '3d meshing of a helix with layer generation' as a template. The results I am getting are way better than before but not as good as they need to be.
I managed to generate that one perfect layer but with increasing the number of layers problems begin to show up again. I am using an expansionRatio of 1.0. I have attached images of the same location for 5, 10 and 15 layers. I need layers up to about 40-50 meters of my domain and at the current state my layer thickness is at 1m. Having an expansionRatio anything more than 1 seems to dramatically worsen the results.
I'm still trying to experiment with different settings in the Dict but it seems that I am not doing it right :/ Mesh generation from the attached pictures is made with the following settings:
Dict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
snap            false;
addLayers       true;
geometry
    domainWoEascii.stl
        name domainWoE;
    waldE.stl
        name waldE;
    E_unten.stl
        name E_unten;
    E_oben.stl
        name E_oben;
    maxLocalCells 10000000;
    maxGlobalCells 200000000;
    // refinement.
    features
    refinementSurfaces
        domainWoE
            level (3 3);
    waldE
            level (3 3);
    E_unten
            level (3 3);
        faceZone E_unten;
        cellZone E_unten;
        zoneInside true;
    E_oben
            level (3 3);
        faceZone E_oben;
        cellZone E_oben;
        zoneInside true;
    // three modes
    refinementRegions
    E_unten
        mode inside;
        levels ((3 3));
    E_oben
        mode inside;
        levels ((3 3));
    // Mesh selection
snapControls
    //  to surface
    nSmoothPatch 3;
    tolerance 2.0;
    nSolveIter 30;
    nRelaxIter 5;
    // Feature snapping
        //  (default=false).
addLayersControls
    relativeSizes true;
    layers
    waldE
            nSurfaceLayers 10;
        finalLayerThickness 0.2;
        expansionRatio 1;
    domainWoE
            nSurfaceLayers 10;
        expansionRatio 1;
    expansionRatio 1.3;
    finalLayerThickness 0.6;
    minThickness 0.001;
    nGrow 0;
    featureAngle 180;
    slipFeatureAngle 60;
    nRelaxIter 4;
    nSmoothNormals 1;
    nSmoothThickness 1;
    maxFaceThicknessRatio 0.5;
    minMedianAxisAngle 20;
    // mesh.
    nLayerIter 50;
    // Max number of iterations after which relaxed meshQuality controls
    // get used. Up to nRelaxIter it uses the settings in meshQualityControls,
    // after nRelaxIter it uses the values in meshQualityControls::relaxed.
    nRelaxedIter 50;
// where to undo.
meshQualityControls
    #include "meshQualityDict.layer"
    // Advanced
    nSmoothScale 4;
// Advanced
// Write flags
writeFlags
    scalarLevels
    layerSets
Quality controls for steps 1 and 2:
|  \\    /   O peration     | Version:  2.3.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      meshQualityDict;
maxNonOrtho 65;
maxBoundarySkewness  20;
maxInternalSkewness  4;
maxConcave 80;
minVol 1e-13;
//  disable.
//      0 = flat tet
//      1 = regular tet
minTetQuality 1e-15;
minArea -1;
// and face centre triangles normal
minTwist 0.02;
//- Minimum normalised cell determinant. This is the determinant of all
//  the areas of internal faces. It is a measure of how much of the
//  outside area of the cell is to other cells. The idea is that if all
//  outside faces of the cell are 'floating' (zeroGradient) the
//  'fixedness' of the cell is determined by the area of the internal faces.
//  1 = hex, <= 0 = folded or flattened illegal cell
//- Relative position of face in relation to cell centres (0.5 for orthogonal
//  mesh) (0 -> 0.5)
minFaceWeight 0.05;
//- Volume ratio of neighbouring cells (0 -> 1)
minVolRatio 0.01;
//- Per triangle normal compared to average normal. Like face twist
//  but now per (face-centre decomposition) triangle. Must be >0 for Fluent
//  compatibility
//- if >0 : preserve cells with all points on the surface if the
//  resulting volume after snapping (by approximation) is larger than
//  minVolCollapseRatio times old volume (i.e. not collapsed to flat cell).
//  If <0 : delete always.
minVolCollapseRatio 0.1;
relaxed
Quality controls for layer addition:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
maxNonOrtho 180;//65;
maxBoundarySkewness -1;// 20;
maxInternalSkewness -1; //4;
maxConcave 180;//80;
minVol -1e30; //1e-13;
//  disable.
//      0 = flat tet
//      1 = regular tet
minTetQuality -1e30; //1e-15;
minArea -1;
minTwist 0.02;
//  mesh) (0 -> 0.5)
minFaceWeight 0.05;
minVolRatio 0.01;
//  compatibility
relaxed
Best,
Tim
Old   August 2, 2015, 22:51
DanielP
Hello Tim,
Since you need a very thick boundary layers relative to your domain, I suggest that you changed the following points:
-Change nCellsBetweenLevels to 1
-reduce the refinement to level to 2 for all the surfaces
-Set the tolerance to 1
- I have notice that you using the explicitFeatureSnap without the features
being defined in the features section of the castellatedMeshControls.Please see
this thread:
http://www.cfd-online.com/Forums/ope...-new-post.html
-You can try and set the relativeSize to false. This way all you declared values for the boundary layers are not relative but true values.
-Lower the slipFeatureAngle to say 10. This will control of the points are extruded between patches.
-Lower the minMedianAxisAngle to 5.
The values of the finalLayerThickness and expansionRatio are use in calculating the finalThickness of the total number of specified boundary layers. This specified value is use when snappyHexMesh tries to generated the boundary layers.
Note also that the Snap mesh must be displace in order to make room for
the Addlayer mesh. The internal displacement of the points are limited by the
mesh quality parameters that control the quality of the elements.
Thanks,
Daniel
Yanagi likes this.
collapsing, layer, prism, snappyhexmesh
[snappyHexMesh] Layers collapsing max.pow OpenFOAM Meshing & Mesh Conversion 6 October 15, 2021 05:54
[snappyHexMesh] Collapsing layers RomCFD OpenFOAM Meshing & Mesh Conversion 5 January 18, 2020 01:39
[snappyHexMesh] Collapsing layers michi.ka OpenFOAM Meshing & Mesh Conversion 6 September 22, 2018 09:20
[snappyHexMesh] Layers collapsing problem Manideep Reddy OpenFOAM Meshing & Mesh Conversion 2 March 12, 2018 07:09
[snappyHexMesh] SHM addLayers problem: boundary layers collapsing on a patch DOFuser OpenFOAM Meshing & Mesh Conversion 1 October 22, 2015 08:09
