[Gmsh] element connectivity in gmsh file
Like Tree1Likes
  • 1 Post By aljazari
Old   April 13, 2016, 12:24
Unhappy element connectivity in gmsh file
Mayank Patni
mayankpatni is on a distinguished road
Dear All,
I am new to OpenFOAM Gmsh. I am using below commands to generate a 2D mesh with 2nd order:
// Gmsh project created on Wed Apr 13 13:55:50 2016
lc = 1e-5;
Point(1) = {-10,0,-10,lc};
Point(2) = {10,0,-10,lc} ;
Point(3) = {10,0,10,lc} ;
Point(4) = {-10,0,10,lc} ;
Line(1) = {1,2} ;
Line(2) = {2,3} ;
Line(3) = {3,4} ;
Line(4) = {4,1} ;
Line Loop(5) = {4,1,2,3} ;
Plane Surface(6) = {5};
Transfinite Line{1,2,3,4} = 3;
Transfinite Surface{6};
Recombine Surface{6};
When I save the msh file and read to check the element connectivity, it gives as below :
$Elements
16
1 15 2 0 1 1
2 15 2 0 2 2
3 15 2 0 3 3
4 15 2 0 4 4
5 8 2 0 1 1 5 6
6 8 2 0 1 5 2 7
7 8 2 0 2 2 8 9
8 8 2 0 2 8 3 10
9 8 2 0 3 3 11 12
10 8 2 0 3 11 4 13
11 8 2 0 4 4 14 15
12 8 2 0 4 14 1 16
13 10 2 0 6 4 14 17 11 15 18 19 13 20
14 10 2 0 6 11 17 8 3 19 21 10 12 22
15 10 2 0 6 14 1 5 17 16 6 23 18 24
16 10 2 0 6 17 5 2 8 23 7 9 21 25
$EndElements
Ideally it should be only 4 elements (4 9-noded elements). How to remove the elements from 1-12 ?
Any suggestions would be helpful.
Thanks !
mayankpatni is offline   Reply With Quote
Old   April 15, 2016, 10:09
Abdulhaq
aljazari is on a distinguished road
c = 1e-5;
Line(1) = {1,2} ;
Line(2) = {2,3} ;
Line(3) = {3,4} ;
Line(4) = {4,1} ;
Physical Surface(1) = {6};
You need to add a physical surface. This should leave you with four elements.
mayankpatni likes this.
aljazari is offline   Reply With Quote
Old   April 15, 2016, 10:17
Mayank Patni
Hello Abdulhaq,
Thank you so much for your reply. This is what I was looking.
I have one more question. When I read the mesh file, its like
$MeshFormat
2.2 0 8
$EndMeshFormat
$Nodes
9
1 -10 0 -10
2 10 0 -10
3 10 0 10
4 -10 0 10
5 -1.232614010859834e-11 0 -10
6 10 0 -1.232614010859834e-11
7 1.232614010859834e-11 0 10
8 -10 0 1.232614010859834e-11
9 0 0 1.519298140712631e-23
$EndNodes
$Elements
4
1 3 2 1 6 4 8 9 7
2 3 2 1 6 7 9 6 3
3 3 2 1 6 8 1 5 9
4 3 2 1 6 9 5 2 6
$EndElements
How to get the coordinates as 0 instead of very small numbers for nodes 5-9 ?
Regards
Mayank
Old   April 15, 2016, 11:27
Abdulhaq
You are welcome.
There is no apparent way to control the precision.
Smoothing the mesh replaced the node which contained "e-23" with 0 but nothing else.
You can smooth the mesh either from the command line:
gmsh -2 input.geo -smooth 20
or by adding the following in the geometry file:
Mesh.Smoothing = 20;
element connectivity, gmsh, mesh 2d, msh file
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 8, 2019 23:50
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
