[Gmsh] Compiling with OpenCascade
Old   September 22, 2008, 10:47
Default Compiling with OpenCascade
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
When I tried to open a CAD STEP-file with gmsh there is an error that I should compile gmsh with OpenCascade.
What does that mean and how is this possible?
I have downloaded the OpenCascade file, but don't know what to do with it.
There is no documentation of how to compile OpenCascade itself or even with gmsh.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   September 22, 2008, 11:17
Default Usually Gmsh comes with OpenCA
Billy
billy is on a distinguished road
Usually Gmsh comes with OpenCASCADE. Maybe you downloaded wrong version.
billy is offline   Reply With Quote
Old   September 22, 2008, 12:28
Default I got the version directly fro
sega's Avatar
Sebastian Gatzka
I got the version directly from the (k)ubuntu server. Maybe thats the problem.
I will try using the file from the website.
Old   September 22, 2008, 12:35
Default Compiling stuff again. The
sega's Avatar
Sebastian Gatzka
The FAQ.txt of gmsh from the website sais:
* 2.4 How do I compile Gmsh?
Just type './configure; make; make install'. If you change some
configuration options (type './configure --help' to get the list of
all available choices), don't forget to do 'make clean' before
rebuilding Gmsh
Where do I have to put these commands?
If I run ./configure in the gmsh directory there is an error bash: ./configure: No such file or directory
Whats wrong?
Old   September 22, 2008, 13:23
Default Damn it. I have downloaded th
sega's Avatar
Sebastian Gatzka
Damn it.
I have downloaded the "stable release" for Linux, which is no source code at all.
(What is is good for?)
Now I have used the source code an compiled it.
But the error is still the same.
What now?
[Gmsh] How to install OpenCASCADE for Gmsh 3.0.6 ? deepbandivadekar OpenFOAM Meshing & Mesh Conversion 1 June 13, 2018 05:31
Getting error both interpreting and compiling serene6390 Fluent UDF and Scheme Programming 1 October 27, 2017 00:49
All files present. but solver not compiling saddy OpenFOAM Programming & Development 1 July 29, 2017 09:50
[OpenFOAM.org] Trouble Compiling OpenFOAM-dev using Intel Compiler 15 for use on Xeon Phi foamer123 OpenFOAM Installation 9 August 20, 2015 14:03
Help with KIVA4 source code compiling geothokar Main CFD Forum 0 September 3, 2010 05:40
