[Gmsh] Undefined faces in mesh
Old   May 12, 2006, 12:14
Default Undefined faces in mesh
Giuseppe Noviello
derath is on a distinguished road
Hi to all
I've made a simple case (cube) using GMSH, so when I use gmshToFoam to convert it I've this :
Exec : gmshToFoam /home/giuseppe/OpenFOAM/giuseppe-1.3/run/tutorials/potentialFoam cubo aaaa.msh
Date : May 12 2006
Time : 18:17:59
Host : linux
PID : 8374
Root : /home/giuseppe/OpenFOAM/giuseppe-1.3/run/tutorials/potentialFoam
Case : cubo
Nprocs : 1
Create time
Read nVerts:865
Read nElems:4928
Mapping region 6 to Foam patch 0
Mapping region 15 to Foam patch 1
Mapping region 19 to Foam patch 2
Mapping region 23 to Foam patch 3
Mapping region 27 to Foam patch 4
Mapping region 28 to Foam patch 5
Mapping region 1 to Foam cellZone 0
Cells:
total:4016
hex :0
prism:0
pyr :0
tet :4016
Patches:
Patch Size
0 228
1 94
2 94
3 94
4 86
5 228
CellZones:
Zone Size
0 4016
--> FOAM Warning :
From function polyMesh::polyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 573
Found 824 undefined faces in mesh; adding to default patch.
Finding faces of patch 0
Finding faces of patch 1
Finding faces of patch 2
Finding faces of patch 3
Finding faces of patch 4
Finding faces of patch 5
FaceZones:
Zone Size
Writing zone 0 to cellZone cellZone_0 and cellSet
End
I'm doing somethings of wrong?
Thanks in advantage
Giuseppe
derath is offline   Reply With Quote
Old   May 13, 2006, 06:57
Default Not necessarily wrong. What t
Hrvoje Jasak
Not necessarily wrong. What this says is that OpenFOAM has found 824 faces external to your geometry that did not have a boundary condition associated with them and it has collected them together in a patch.
If you think you have defined boundary types on the complete external surface of the model, there is a reason to worry; otherwise, just have a look at the default patch and see if it looks OK or not.
Enjoy,
Hrv
Hrvoje Jasak
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
[snappyHexMesh] SHM is not extruding/adding Layers everywhere matthiasd OpenFOAM Meshing & Mesh Conversion 2 October 16, 2016 16:45
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
