[Gmsh] Cyclic boundaries
Old   February 7, 2006, 09:20
Default Cyclic boundaries
diablo80@web.de
sampaio is on a distinguished road
Is it possible to generate cyclic physical boundaries in gmsh and/or reorder the faces number generated in gmsh so that OF can deal with the mesh?
Or else, how can one build a OF cyclic geometry out of a gmsh mesh?
Thanks a lot.
sampaio is offline   Reply With Quote
Old   February 7, 2006, 13:26
Default Try the createPatch utility. I
Mattijs Janssens
mattijs is on a distinguished road
Try the createPatch utility. It only takes care of the face ordering however, it does require GMSH to have produced a mesh with exactly same faces on opposite sides.
mattijs is offline   Reply With Quote
Mapped vs Cyclic Boundaries in OpenFOAM arsenis OpenFOAM Running, Solving & CFD 1 February 8, 2023 21:13
[mesh manipulation] Problem with using createPatchDict to define cyclic boundaries kaszt OpenFOAM Meshing & Mesh Conversion 0 April 1, 2016 21:18
No flow through periodic (cyclic) boundaries in impeller with foam-extend-3.1 anttiad9000 OpenFOAM Running, Solving & CFD 3 March 2, 2016 19:37
Possible createPatch/createBaffles bug? simpomann OpenFOAM Bugs 2 July 15, 2014 07:07
Wrong wall distance with cyclic boundaries sebastian OpenFOAM Bugs 4 October 31, 2012 10:24
