[Netgen] Same mesh on inlet and outlet
Old   November 21, 2008, 03:18
Default Same mesh on inlet and outlet
Henning Wilhelmi
henning is on a distinguished road
Hi everyone!
I want to make a channelOodle case with a pipe generated in netgen (tet mesh). Converting is not a problem (except patch 0 has 0 faces so I just deleded it) but when I run the channelOodles command I get:
Attempt to cast type patch to type lduInterface#0 Foam::error::printStack(Foam:stream&) in "/home/fs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/fs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam:stream& Foam::operator<<>(Foam:stream&, Foam::errorManip<foam::error>) in "/home/fs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/channelOodles"
#3 Foam::lduInterface const& Foam::refCast<foam::lduinterface>(Foam::fvPatch const&) in "/home/fs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#4 Foam::cyclicFvPatchField<double>::cyclicFvPatchFie ld(Foam::fvPatch const&, Foam::DimensionedField<double,> const&, Foam::dictionary const&) in "/home/fs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#5 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<foam::cyclicfvpatchf ield<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double,> const&, Foam::dictionary const&) in "/home/fs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#6 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double,> const&, Foam::dictionary const&) in "/home/fs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/channelOodles"
#7 Foam::GeometricField<double,>::GeometricBoundaryFi eld::GeometricBoundaryField(Fo am::fvBoundaryMesh const&, Foam::DimensionedField<double,> const&, Foam::dictionary const&) in "/home/fs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/channelOodles"
#8 Foam::GeometricField<double,>::readField(Foam::Ist ream&) in "/home/fs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/channelOodles"
#9 Foam::GeometricField<double,>::GeometricField(Foam ::IOobject const&, Foam::fvMesh const&) in "/home/fs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/channelOodles"
#10 main in "/home/fs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/channelOodles"
#11 __libc_start_main in "/lib64/libc.so.6"
#12 __gxx_personality_v0 in "/home/fs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/channelOodles"
From function refCast<to>(From&)
in file /home/fs/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/typeInfo.H at line 106.
FOAM aborting
Aborted
I assume it's because inlet (patch2) and outlet (patch3) don't have the same mesh on the surface.
So my question is: How to solve this problem? Maybe create the same mesh on in- and outlet? But how?
Thanks for your help
Henning =)
henning is offline   Reply With Quote
Old   November 27, 2008, 09:53
Default OK, I tried it in a different
Henning Wilhelmi
OK, I tried it in a different way and now inlet and outlet are the same patch but dont have faces that directly blong to another and I get this:
face 0 area does not match neighbour 6912 by 1.62797% -- possible face ordering problem.
patch:inout my area:4.24561e-06 neighbour area:4.17705e-06 matching tolerance:0.001
Mesh face:1255168 vertices:3((0 0.044188 -0.086535) (0 0.046249 -0.088662) (0 0.043565 -0.090012))
Neighbour face:1262080 vertices:3((0.1 0.044152 0.086605) (0.1 0.046263 0.088655) (0.1 0.043578 0.090005))
Rerun with cyclic debug flag set for more information.
From function cyclicPolyPatch::calcTransforms()
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 150.
FOAM exiting
Any suggestions on that would be great =)
Henning
Old   January 16, 2009, 03:36
Default i am new to openfoam. i need t
VIJAYAKUMAR R
vijayakumar is on a distinguished road
i am new to openfoam. i need to solve a simple methane combustion problem............ which solver is bettter for combustion(XIFOAM, XOODELS so many is there) and please give me few guidelines to solve a combustion problem...
vijayakumar is offline   Reply With Quote
Old   January 16, 2009, 04:39
Default Personally I would use XiFoam
Henning Wilhelmi
Personally I would use XiFoam for a first try and compare it to experimental results to see if it fits your needs. LES is a bit more realistic but also needs more time to be solved.
But I am quite new to CFD myself so be careful with that advice =)
Reversed flow using pressure inlet and outlet? here_for_help FLUENT 0 September 28, 2018 15:20
Fan simulation with inlet and outlet duct for finding fan curve chaudhry_hashim FLUENT 0 August 6, 2014 10:49
flow around a circular cylinder with velocity inlet and outflow outlet shuoxue OpenFOAM 1 March 3, 2014 10:42
flow around a circular cylinder with velocity inlet and outflow outlet shuoxue OpenFOAM Running, Solving & CFD 0 November 2, 2013 04:32
Inlet and Outlet b.c. based on mass flux Hale OpenFOAM Pre-Processing 2 August 9, 2013 02:26
