[Salome] ExtrudeMesh for Dummies
Old   October 28, 2008, 03:21
Default ExtrudeMesh for Dummies
Wolfgang Heydlauff
wolle1982 will become famous soon enough
here is an easy one. But still, I cannot figure it out. As an OpenFOAM Newbie I want to calculate a 2D Mesh with OF (airfoil). My 2D structure is meshed with SalomeMeca. Converting with ideasUnvToFoam doesn't work because of the lack of the third dimension.
What I do now is: I extrude the mesh in Salome. Define the boundaries. Export/Import it via ideasUnvToFoam.
So far so good. Defining the Borders is in my mind complicated while you have to select every single border-face itself (to group it). Isn't there an easier way??
The best would be to use the extrudeMesh tool. BUT here is my problem: For the extrudeMesh I need a 2D Mesh opened in OpenFOAM (FoamX Case). How do I get the 2D Mesh inside FoamX in the first place ???
I also tried to go over gmsh (import/export) since the gmshToFoam can import 2D Meshes. gmsh doesn't realize the mesh itself. So I cannot manipulate it (e.g. extrude it). But by using the extrudeMesh it doesn't create patches, faces or anything (except the second set of Vertexes). I tried to run blockMesh. But this need the blockMeshDict, which I don't have... It only gives me the "originalPatch, othersidePatch, rest"
Can anyone tell me the most comfort way to mesh an calculate an 2D airfoil (structured/hybrid grid)?!
The fluentMeshToFoam tool is great since it extrudes the Mesh itself. Poorly I don't have possibily to export from sSalome into FluentMesh.
Later I will have to calculate a complex 3D airfoil. I'm not sure if Salome is so friendly for this task. Any suggestions?
Thanks a lot!
wolle1982 is offline   Reply With Quote
Old   October 28, 2008, 03:46
Default Hi, in Salome you can group
tian's Avatar
Tian
tian is on a distinguished road
in Salome you can group your geometrie at first, than mesh it. "Create Group -> Group Type: Group on geometry"...
Have fun
Bye
Thomas
BIM HVACTool, The Green Building Simulation Tool for OpenFOAM, Energy Plus and Radiance.
tian is offline   Reply With Quote
Old   October 28, 2008, 10:35
Default yes, that would work if I woul
Wolfgang Heydlauff
yes, that would work if I wouldn't extrude the mesh in Salome. See, the groups are Edges. After Extrution I need to define Faces. Since an Edge is devitet in e.g. 20 segments, afterwards I would have 20 Faces.
Keeps the question: How to use the extrudeMesh tool from OF with an 2D Mesh from Salome? I just cannot get the Mesh in FoamX or elsewhere.
[mesh manipulation] extrudeMesh can't find any patches shang2 OpenFOAM Meshing & Mesh Conversion 6 February 26, 2021 20:46
[mesh manipulation] extrudeMesh limits Adaptive/Dynamic Mesh Refinenemt potentialFoam OpenFOAM Meshing & Mesh Conversion 3 January 29, 2018 03:42
[mesh manipulation] Generating 3-D axisymmetric mesh using extrudeMesh martyn88 OpenFOAM Meshing & Mesh Conversion 17 June 21, 2017 19:42
[snappyHexMesh] Problem with extrudeMesh sHM 2D airfoil mesh ssss OpenFOAM Meshing & Mesh Conversion 2 September 1, 2014 13:12
[snappyHexMesh] snappyHexMesh after extrudeMesh / Creating background mesh with extrudeMesh pythag0ra5 OpenFOAM Meshing & Mesh Conversion 3 September 11, 2013 09:10
