[snappyHexMesh] How to use SHM for this particular case?
Old   January 5, 2011, 19:25
Default How to use SHM for this particular case?
kalyan
hardykalyan is on a distinguished road
I have a ventilator fan .stl file. I need to fit this into a rectangular box of particular dimensions. I want this box to be filled with air. I dont have an stl file for this box and hence want to generate this rectangular box in the blockmesh directly.
Here are the following questions I need some help
1) Can i use the required rectangular box dimensions as the base design in the blockMeshDict file or should i define the box and the base design both with their respective dimensions or should i create the box as a .stl file and then use a base design to include both the fan and rectangular stl files? Also can i use the air rectangular box as the refinement region? where should i have the location in mesh? inside ventilator or the air region?
2) for working with MRF we require cellzones, hence howz it possible to obtain the cells for the ventilator and air region seperately? Can i use cylinderToCell in cellSetDict and if i use it does it also include the air regions between the wings of the ventilator?
Can any help me with these issues?
hardykalyan is offline   Reply With Quote
[snappyHexMesh] SHM not snapping on simple case slaners OpenFOAM Meshing & Mesh Conversion 7 June 6, 2018 06:43
[snappyHexMesh] SHM not snapping on simple case slaners OpenFOAM Meshing & Mesh Conversion 2 June 5, 2018 08:59
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
CFD Post - How to check for case in an expression pilakin ANSYS 0 September 26, 2014 04:44
Transient case running with a super computer microfin FLUENT 0 March 31, 2009 11:20
