[Gmsh] IO error using gmshToFoam
Old   March 15, 2011, 17:30
Default IO error using gmshToFoam
Emilie Garnier
Emilie is on a distinguished road
Hello guys,
I am new to OpenFoam and I tried to create a very simple mesh : a cavity, with Gmsh.
My mesh looks great, however, when I save it as a .msh file, Gmsh offers several options :
-Version 1.0
-Version 2.0 Binary
-Version 2.0 ASCII
and the options:
-save all (ignore physical groups)
-save parametric coordinates
I tried all the options but eliminated the 'binary', 'save all' and 'save parametric coordinates' because they didn't seem useful.
I finally chose the 2.0 ASCII without ticking the two options.
When I use the "gmshToFoam" command, I have this error :
Create time
Found $MeshFormat tag; assuming version 2 file format.
Starting to read mesh format at line 2
Read format version 2.1 ascii 0
Starting to read points at line 5
Vertices to be read:10498
Vertices read:10498
Starting to read cells at line 10506
Cells to be read:10496
Mapping region 30 to Foam patch 0
Mapping region 31 to Foam patch 1
Mapping region 29 to Foam patch 2
Cells:
total:0
hex :0
prism:0
pyr :0
tet :0
--> FOAM FATAL IO ERROR:
No cells read from file "carre_parfait_test_renomme.msh"
Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)?
Perhaps you have not exported the 3D elements?
file: carre_parfait_test_renomme.msh at line 21004.
From function readCells(..)
in file gmshToFoam.C at line 719.
FOAM exiting
Does anyone ever had this error/know where it comes from ?
Thank you very much for your help !
Versions : OpenFoam 1.7.1 and Gmsh 2.4.2
Emilie is offline   Reply With Quote
Old   March 16, 2011, 08:45
Arina
Akuji is on a distinguished road
Send a message via ICQ to Akuji
Cells:
total:0
hex :0
prism:0
pyr :0
tet :0
OpenFoam didn't find any cell of your mesh.
When you saved you mesh, what size of .msh file?
Akuji is offline   Reply With Quote
Old   March 16, 2011, 08:48
Arina
Also, if you want to convert 3D mesh from gmsh, you need to define physical volume.
Old   March 16, 2011, 16:30
Emilie Garnier
Thank you for your help Akuji !
Indeed there was a problem with the mesh file : the size was 800kb and 21000 lines.
I defined the volume with Gmsh before generating the mesh (by clicking on 3D) and now my mesh file has a size of 9Mb and over 160000 lines.
The foamToGmsh command returned me a better message, except for :
--> FOAM Warning :
From function polyMesholyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 576
Found 10496 undefined faces in mesh; adding to default patch.
but I don't think it'll be a problem, I just need to modify the boundary file concerning the default faces.
Anyway, thank your very much !
[Gmsh] New version of gmshToFoam? stootoon OpenFOAM Meshing & Mesh Conversion 7 February 14, 2022 09:01
[Gmsh] gmshToFoam problem. nilashansen OpenFOAM Meshing & Mesh Conversion 11 June 5, 2016 10:45
[Gmsh] Cell to node connectivity after 'gmshToFoam' Jibran OpenFOAM Meshing & Mesh Conversion 1 June 8, 2015 09:09
[Gmsh] gmshTofoam pbm with cyclicAMI acahuzac OpenFOAM Meshing & Mesh Conversion 2 October 20, 2014 03:53
[Gmsh] gmshToFoam command mvinassa OpenFOAM Meshing & Mesh Conversion 1 April 25, 2014 07:36
