[mesh manipulation] decomposePar results in a weired procBoundary
Old   March 15, 2013, 04:24
Default decomposePar results in a weired procBoundary
luliqiang
luliqiang is on a distinguished road
as you see from the attachment, the procBoundary is not flat. How can i get a flat procBoundary? thank you.
ps. my decomposeParDic as follows.
numberOfSubdomains 5;
method          simple;
simpleCoeffs
    n               ( 5 1 1 );
    delta           0.001;
luliqiang is offline   Reply With Quote
Old   March 15, 2013, 04:28
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
I you have some specific requirements on the decomposition, e.g. flat processor boundaries, then I suggest that you use the manual decomposition method, where you specify, which processors the individual cells belong to.
It is a quite simple operation, which you could e.g. based on the cell centres, which you can obtain based on
writeCellCentres
Kind regards,
Niels
ngj is offline   Reply With Quote
Old   March 15, 2013, 05:53
luliqiang
Originally Posted by ngj View Post
writeCellCentres
Kind regards,
Niels
thank u Niels. I got it, with a modified writeCellCentre file. just add a few lines:
forAll(cci, cellID)
    pid = (int)(cci[cellID]/LX);    //cellID belongs to which process
    fprintf(fSrc, "%d\n", pid);    //output
    sum[pid]++;            //sum
the dataFile is:
FoamFile
version 2.0;
format ascii;
class labelList;
location "constant";
object decompDict;
124218    //number of cells
3    // first cell belongs to process 3
0    // second cell belongs to process 0
x    // the cell belongs to process x
2    // last cell belongs to process 2
Old   March 18, 2013, 08:43
ngj
Hi
This thread has a nice description of how to create the file for manual decomposition:
http://www.cfd-online.com/Forums/ope...computing.html
/ Niels
Error Interpolating Results onto New Mesh nammeh CFX 1 March 26, 2019 12:08
decomposePar 4-core warning/error? Boloar OpenFOAM Bugs 23 April 8, 2014 08:57
Creating a tool to interpolate results Luis Batista OpenFOAM Running, Solving & CFD 2 April 11, 2013 08:15
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 11:33
wind tunnel results vs fluent pixie Main CFD Forum 1 August 20, 2009 08:02
