[mesh manipulation] MapConsistentVolField.H and IOobjectList |
June 5, 2018, 04:17 |
krishna kant
Rep Power: 10 |
Hi I am new in C++ so I dont know the structure database used in openFoam. The problem I am facing is typically a programming language problem. I dont know the correct command for my purpose. Any help will be deeply appreciated.
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 2011-2015 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. \*---------------------------------------------------------------------------*/ #ifndef MapConsistentVolFields_H #define MapConsistentVolFields_H #include "GeometricField.H" #include "meshToMesh0.H" #include "IOobjectList.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { template<class Type, class CombineOp> void MapConsistentVolFields ( const IOobjectList& objects, const meshToMesh0& meshToMesh0Interp, const meshToMesh0:rder& mapOrder, const CombineOp& cop ) { const fvMesh& meshSource = meshToMesh0Interp.fromMesh(); const fvMesh& meshTarget = meshToMesh0Interp.toMesh(); word fieldClassName ( GeometricField<Type, fvPatchField, volMesh>::typeName ); IOobjectList fields = objects.lookupClass(fieldClassName); Info<< " interpolating " << fields.lookup(name) << endl; forAllIter(IOobjectList, fields, fieldIter) { Info<< " interpolating " << fieldIter()->name() << endl; // Read field GeometricField<Type, fvPatchField, volMesh> fieldSource ( *fieldIter(), meshSource ); IOobject fieldTargetIOobject ( fieldIter()->name(), meshTarget.time().timeName(), meshTarget, IOobject::MUST_READ, IOobject::AUTO_WRITE ); if (fieldTargetIOobject.headerOk()) { // Read fieldTarget GeometricField<Type, fvPatchField, volMesh> fieldTarget ( fieldTargetIOobject, meshTarget ); // Interpolate field meshToMesh0Interp.interpolate ( fieldTarget, fieldSource, mapOrder, cop ); // Write field fieldTarget.write(); } else { fieldTargetIOobject.readOpt() = IOobject::NO_READ; // Interpolate field GeometricField<Type, fvPatchField, volMesh> fieldTarget ( fieldTargetIOobject, meshToMesh0Interp.interpolate ( fieldSource, mapOrder, cop ) ); // Write field fieldTarget.write(); } } } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // } // End namespace Foam // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #endif // ************************************************** *********************** // The above is a code for MapConsistentVolField.H, I have issue with the line highlighted/underlined. In that line the "fields" is suppose to take list of all the variables like P,T for classtype volScalar. How can I check that list of variables stored in fields. I am trying commands like fields.lookup(name) to know the name of the variables that is in the list of fields. It is showing error "MapConsistentVolFields.H:56:52: error: no matching function for call to ‘Foam::IOobjectList::lookup(<unresolved overloaded function type>)’". what is the correct command for this purpose? |
[OpenFOAM] Acquiring scalar names | tj22 | ParaView | 4 | May 17, 2006 13:01 |
