[Commercial meshers] FluentMeshToFoam problem |
September 10, 2014, 05:00 |
Vito Fasano
Rep Power: 12 |
Hello Foamers,
i'm working on the common problem of rotor-stator. My rotor is "immerged" in an environment. I've 2 different meshes, rotor and environment. I used the command fluentMeshToFoam to use them in openfoam. Than i rescale the rotor with the command transformPoints, and now rotor and environment have the same height. After that, i use the command mergeMeshes to merge rotor and environment. I create a dictionary topoSetDict to create a cylinder region (rotating region), named rotor. When i use checkMesh the check failed with this error: Mesh stats points: 112010 internal points: 4 faces: 361044 internal faces: 156380 cells: 101680 faces per cell: 5.08875 boundary patches: 9 point zones: 0 face zones: 0 cell zones: 1 Overall number of cells of each type: hexahedra: 9024 prisms: 92656 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. ***Unused points found in the mesh, number unused by faces: 4 number unused by cells: 4 <<Writing 4 unused points to set unusedPoints Upper triangular ordering OK. Face vertices OK. *Number of regions: 2 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 with 37802 cells to cellSet region0 <<Writing region 1 with 63878 cells to cellSet region1 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology AIRFOIL_DX 376 752 ok (non-closed singly connected) AIRFOIL_SX 376 752 ok (non-closed singly connected) frontAndBackPlanes 203360 112006 ok (non-closed singly connected) AMI1 200 400 ok (non-closed singly connected) INLET 38 78 ok (non-closed singly connected) OUTLET 38 78 ok (non-closed singly connected) WALL_DX 38 78 ok (non-closed singly connected) WALL_SX 38 78 ok (non-closed singly connected) AMI2 200 400 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-60 -40 -1.69706) (60 80 1.69706) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (6.94185e-18 -4.84503e-18 2.93105e-24) OK. Max cell openness = 3.26067e-15 OK. Max aspect ratio = 86.65 OK. Minimum face area = 3.17962e-08. Maximum face area = 15.9533. Face area magnitudes OK. Min volume = 1.0792e-07. Max volume = 26.1164. Total volume = 48875.1. Cell volumes OK. Mesh non-orthogonality Max: 47.1422 average: 2.35539 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.40473 OK. Coupled point location match (average 0) OK. Failed 1 mesh checks. End I don't know which is the error, because on fluent it works. I hope someone can help me! This is my polymesh directory: https://www.dropbox.com/s/4odldp1xfc...sh.tar.gz?dl=0 Best regards Vito |
September 10, 2014, 07:42 |
I am a new user of OpenFOAM but I think it is all about multiple fluid meshes, or multiple regions.
Hope this helps !! Thanks and Regards, Adarsh Tiwari |
September 10, 2014, 09:18 |
Vito Fasano
Rep Power: 12 |
Thanks for the reply adarsh tiwari,
but it's strange, because the calculation is in progress now..I hope someone has experience in this type of situation! |
January 11, 2023, 16:20 |
Rep Power: 8 |
I believe this issue is encountered when you have some duplicate nodes. In your meshing software, look for an option to merge nodes. and re-export your mesh. This should solve this issue.
"When in doubt, use brute force." -- Ken Thompson |
Is COMSOL Multi Physics is suitable to solve complex flow problem? | steve lee | COMSOL | 8 | January 5, 2023 02:31 |
BuoyantBoussinesqSimpleFoam_Facing problem | Mondal131211 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2019 19:41 |
Mesh& steptime independant: conduction-convection problem | Fati1 | Main CFD Forum | 1 | October 28, 2018 13:52 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
