[Commercial meshers] error in Fluentmeshtofoam
Old   April 26, 2015, 04:00
Default error in Fluentmeshtofoam
khalifa is on a distinguished road
Hi people ,
I am trying to convert a mesh I already built in Ansys workbench to use it in openfoam and I am getting errors. I read here some previous similar cases but nothing could solve my error.
this is what I am getting :
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/khalifa/OpenFOAM/khalifa-2.3.1/run/tutorials2/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
I converted to ascii already and nothing changed .
your kind help will be much appreciated
khalifa is offline   Reply With Quote
Old   May 6, 2015, 03:45
Paritosh Vasava
vasava will become famous soon enough
I guess you know this already but you can try this trick if you haven't. This trick ensures that the mesh exported from Ansys Meshing is in ASCII format.
  1. Open Ansys Meshing.
  2. Go to tools -->options (this will open a new options window).
  3. Go to Meshing-->Export. Expand Ansys Fluent and select ASCII for Format of Input File (*.msh).
Although the change should be effective immediately but you can restart workbench in case it does not work.
vasava is offline   Reply With Quote
[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised" preibie OpenFOAM Meshing & Mesh Conversion 28 March 29, 2017 04:56
[Commercial meshers] Converting an abaqus mesh using matlab scripts and fluentMeshToFoam MichaelD OpenFOAM Meshing & Mesh Conversion 1 July 2, 2014 06:34
[Commercial meshers] fluentMeshToFoam instead of fluent3DMeshToFoam sasanghomi OpenFOAM Meshing & Mesh Conversion 2 March 29, 2013 07:58
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam jlpelerin OpenFOAM Meshing & Mesh Conversion 4 April 25, 2011 16:56
[Commercial meshers] Error fluentMeshToFoam loneboard OpenFOAM Meshing & Mesh Conversion 26 February 6, 2009 10:20
