[Commercial meshers] Error fluentMeshToFoam
Old   February 4, 2009, 03:04
Default hi Maruthamuthu Venkatraman si
  #21
NAVEEN.K.M
naveen is on a distinguished road
hi Maruthamuthu Venkatraman sir
could u please send me da procedure of importing fluentMeshTofoam in openfoam 1.4.1..
naveen is offline   Reply With Quote
Old   February 4, 2009, 03:07
  #22
NAVEEN.K.M
i am from india..could u please send me da procedure of importing fluentMeshTofoam in openfoam 1.4.1..i hav written my file in ascii format in fluent..i am facing difficult for converting into openfoam...could u please help me regarding this...
Old   February 4, 2009, 03:35
Default No worries. Follow the instruc
  #23
maruthamuthu_venkatraman is on a distinguished road
No worries. Follow the instructions step by step.
1. While saving the case file in fluent , i.e.the .msh file from gambit after importing it "UNCHECK" the binary option in the dialog box that ask you to name the File.
2. Make a new work directory and put this file in that work directory. Keep the constant, system and 0 directory in the same work folder. Then use the utility FluentmeshToFoam filename.msh
3. It writes a new file for you. The boundary folder inside polymesh will describe all the boundary name that u set in FLUENT...
4. Follow the instructions in 5.5.1 in user guide OPENFOAM as well.
Let me know the result.
maruthamuthu_venkatraman is offline   Reply With Quote
Old   February 4, 2009, 04:48
  #24
NAVEEN.K.M
thanks for your guidance...v imported successfully..
Old   February 6, 2009, 03:49
  #25
NAVEEN.K.M
i am from india..i imported naca 0012 airfoil (.msh)(C GRID) file into openfoam successfully..now i need to solve this in Foam X...CAN U SEND ME DADETAILED PROCEDURE HOW TO solve in openfoam 1.4.1
Old   February 6, 2009, 03:57
  #26
NAVEEN.K.M
Old   February 6, 2009, 10:20
Default Hello Naveen, I would requ
  #27
Rishi .
hellorishi is on a distinguished road
Hello Naveen,
I would request/recommend you to spend some time to read the user guide, wiki, forums and tutorials carefully (twice if required), before jumping and posting(rather SPAMMING different boards with same/similar messages)
Here are some links to start with:
http://openfoamwiki.net/index.php/Main_Tutorials
another self-explainatory slide by slide link(but in german and for OF-1.2. You can use http://dict.leo.org or google translate to help yourself)
http://openfoamwiki.net/images/5/53/...ial_german.zip
and ofcourse dont forget User guide
http://foam.sourceforge.net/doc/Guides-a4/UserGuide.pdf
Spamming on such large scales is definately not earning you a good reputation and thereby reducing your chances of getting a reply. Please dont feel offended.
hellorishi is offline   Reply With Quote
