[Commercial meshers] Naca 0012 airfoil
Old   January 27, 2009, 03:52
Default Naca 0012 airfoil
NAVEEN.K.M
naveen is on a distinguished road
HI EVERYBODY
i hav created a naca 0012 airfoil in gambit and i solved in fluent...now i need to convert it into openfoam 1.4.1....i need how to import FROM fluentMeshTofoam of fluent 6.3 version ...
naveen is offline   Reply With Quote
Old   January 27, 2009, 11:36
Default I am not sure to get what you
maddalena's Avatar
maddalena
maddalena will become famous soon enough
I am not sure to get what you mean, but fluentMeshToFoam meshfile.msh -case casename -scale scalecoeff works for me, with meshfile.msh generated for fluent 6.3. In any case, you can write fluentMeshToFoam -help at your command line.
Hope this help.
Bye
mad
maddalena is offline   Reply With Quote
Old   February 2, 2009, 05:59
Default Gijsbert Wierink sir my pro
NAVEEN.K.M
my problem is that i hav done the naca 0012 airfoil case in gambit and i solved in fluent 6.3 ...now i want to compare these results in openfoam 1.4.1..now i need to import to fluentMeshTofoam in openfoam 1.4.1...can u tell me the procedure how to import the (.msh) file to openfoam 1.4.1..for example i used this format for conversion(my case name is-naca0012.msh) fluentMeshToFoam . naca0012 ./naca0012/naca0012.msh -scale 0.001 but the case is not running in foamX....PLEASE HELP ME REGARDING THIS..
Old   July 7, 2010, 04:27
Sofia
Sofia is on a distinguished road
I calculating the flow around a naca 0015 airfoil in the water but I don't know why my simulation is not correct when I choose k=0.1 and epsilon=30 (k epsilon model)
Have you got an idea?
Thank you
Sofia
Sofia is offline   Reply With Quote
Old   July 8, 2010, 04:46
Sebastian
sebware is on a distinguished road
Hey naveen
1. You copy the fluent meshfile *.msh to the directory of your case.
2. You switch to this directory in your terminal.
3. You run fluentMeshToFoam naca0012.msh
4. run checkMesh to find proplems in the Mesh.
I dont know if in OF 1.4 you have the fluent3DMeshToFoam.
But if you have it, use this one instead of fluentMeshToFoam, I like it.
i hope it helps !
best regards
Sebastian
sebware is offline   Reply With Quote
Old   August 18, 2010, 00:07
darioth's Avatar
Darío Montes
darioth is on a distinguished road
Send a message via MSN to darioth Send a message via Skype™ to darioth
Does anybody tried first with potentialFoam and comment me the correct results in NACA0015 airfoil??
Regards
darioth is offline   Reply With Quote
Old   August 18, 2010, 00:10
darioth's Avatar
Darío Montes
One question: Did you tried with potentialFoam in de NACA0015 first?
Regards
Old   April 14, 2011, 11:03
Default running a sharp NACA with OpenFOAM
jms
José
jms is on a distinguished road
Dear all,
I have run computations for a NACA with a sharp trailing edge (the original one...) using Low-Re meshes and I get high aspect ratio issues (the max AR is about 30000). I run it anyways and I get divergence. Since this airfoil needs a C-mesh, it is inevitable to get this high aspect ratios in the cells of the wake...
Any idea about how to deal with this? (using meshes with low y+ still...)?
Best Regards,
José
jms is offline   Reply With Quote
NACA 0012 Airfoil, simpleFoam, Spalart Allmaras badwalgurpreet OpenFOAM Running, Solving & CFD 11 December 29, 2021 18:04
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
yPlus NACA 0012 Airfoil badwalgurpreet OpenFOAM Running, Solving & CFD 7 March 8, 2019 01:35
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 17:27
2D FFD Optimization RLangtry SU2 2 August 5, 2014 09:48
