[Commercial meshers] Problem with Mesh conversion Gambit msh Foam |
September 6, 2011, 08:01 |
hello Everyone
hi frds
i have some problem so plz help me when i create 2D geometry & complete the mesh in Gambit then i go for fluentMeshToFoam .msh file then it should read & generate the mesh but it took automatically 3D so i cant found my proper streamfunction so plz help me how can i solve that problem |
September 6, 2011, 12:13 |
#2 | |
Daniel P. Combest
frontAndBack { type empty; } Dan |
September 11, 2011, 03:24 |
hello everyone
hi
i m new user of openfoam201 i phase one difficulty when i solved cavity tutorials then i cant found such like fluent after achieving conversion limit, the program didn't stop. but when it reach end time it stop. but i want to stop my program when it go beyond the conversion limit so what can i do for that? plz help me jignesh |
September 11, 2011, 07:58 |
Daniel P. Combest
icoFoam is a time dependent solver so it will continue until endTime. If you want a steady state solver, look at simpleFoam. That solver can do both laminar and turbulent steady state flow.
Dan |
January 16, 2009, 05:12 |
hi everyone
i am new to Op
NAVEEN.K.M
Rep Power: 17 |
hi everyone
i am new to OpenFOAM 1.4.1...I did NACA 0012 Airfoil case in fluent,now i want to compare my results with OpenFOAM...can u tell me da procedure how to import fluent.msh file into OpenFOAM 1.4.1...AND ALSO THE PROCEDURE OF SOLVING AND POST-PROCESSING IN OPENFOAM 1.4.1... |
January 16, 2009, 05:35 |
Hi Naveen,
please stop post
Florian Krause
Rep Power: 17 |
Hi Naveen,
please stop posting the same messages under almost all of the actual existing threads, your are spaming the email postboxes of a lot OF users! If you are new to OF start with tutorials! If you have problems with conversion Fluent to OF use the "Search" function! Florian |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
[Gmsh] Problem with mesh conversion from gmsh | arussell92 | OpenFOAM Meshing & Mesh Conversion | 2 | April 12, 2016 12:05 |
[GAMBIT] mesh problem in gambit...please help | sandi20saze | ANSYS Meshing & Geometry | 4 | February 9, 2014 07:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
