[Sponsors] | |||||
Dear foamers
I drew a mesh in Gridgen, which is attached below file:///home/sujunwei/Desktop/004.png After exporting it with Fluent 2D format, I used the fluentMeshToFoam to convert the mesh into the openfoam native format and used checkMesh to check if the mesh is ok. But I got the following error Create time Create polyMesh for time = constant Time = constant Mesh stats points: 1602 edges: 4855 faces: 4479 internal faces: 1891 cells: 1226 boundary patches: 2 point zones: 0 face zones: 0 cell zones: 0 Number of cells of each type: hexahedra: 240 prisms: 986 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Topological cell zip-up check OK. Face vertices OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface unspecified-4 136 272 ok (not multiply connected) frontAndBackPlanes 2452 1602 ok (not multiply connected) Checking geometry... Domain bounding box: (0 0 -0.0141421) (1 1 0.0141421) Boundary openness (-1.71389e-18 -5.92719e-19 7.71249e-19) OK. ***High aspect ratio cells found, Max aspect ratio: 1.18337e+197, number of cells 1226 <<Writing 1226 cells with high aspect ratio to set highAspectRatioCells Minumum face area = 0.000230689. Maximum face area = 0.00194315. Face area magnitudes OK. Min volume = 1.66667e-300. Max volume = 2e-300. Total volume = 2.12333e-297. Cell volumes OK. #0 Foam::error::printStack(Foam: stream&) at ~/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/OSspecific/Unix/printStack.C:203 #1 Foam::sigFpe::sigFpeHandler(int) at ~/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/OSspecific/Unix/signals/sigFpe.C:130 #2 Uninterpreted: [0xffffe420] #3 ?? in "/lib/libm.so.6" #4 acos in "/lib/libm.so.6" #5 Foam::primitiveMesh::checkFaceOrthogonality(bool, Foam::HashSet<int,> >*) const at ~/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/meshes/primitiveMesh/primitiveMeshCheck/p rimitiveMeshCheck.C:481 #6 Foam::checkGeometry(Foam::polyMesh const&, bool, bool) at ~/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/mesh/manipulation/checkMesh/che ckGeometry.C:95 #7 main at ~/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/mesh/manipulation/checkMesh/che ckMesh.C:107 #8 __libc_start_main in "/lib/libc.so.6" #9 Foam::regIOobject::readIfModified() in "/home/sujunwei/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPDebug/checkMe sh" The errors above indicates that high aspect ratio encountered. However, from the graph above we can find that it is not the truth. In the conversion using fluentMeshToFoam, the mesh can be altered? The mesh file is also attached file:///home/sujunwei/OpenFOAM/sujunwei-1.4.1/run/tutorials/boussinesqBuoyantFoa m/t4.cas Have you encounter similar problems? Best Regards,Junwei |
I have the same error. Did you succeed in solving this issue ?
Regards, Minh |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Help Error fluentMeshToFoam | loneboard | OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... | 26 | February 6, 2009 10:20 |
| Problems with fluentMeshToFoam | su_junwei | OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... | 0 | January 15, 2009 20:01 |
| FluentMeshtoFoam error | sukratu | OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... | 4 | March 7, 2008 22:54 |
| FluentMeshToFoam errorplease help me | andycong | OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... | 18 | November 5, 2007 16:43 |
| FluentMeshToFoam no set written | kian | OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... | 2 | May 25, 2007 12:04 |
