[mesh manipulation] Using refineMesh
Old   February 11, 2008, 09:07
Default Using refineMesh
matteo_gautero
Hi to all,
I have to refine a starting mesh with the tool refineMesh. Can someone explain me how to use this tool? In particular I have to refine a single zone of the mesh and if it is possible to run in parallel refineMesh because the namber of cells are high.
Thenks in advance,
Matteo.
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 13:44
[mesh manipulation] Iterate refineMesh sgr OpenFOAM Meshing & Mesh Conversion 1 May 13, 2015 05:49
[mesh manipulation] checkMesh Erros after refineMesh mgdenno OpenFOAM Meshing & Mesh Conversion 10 October 14, 2014 05:16
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 11:20
checkMesh Errors after refineMesh mgdenno OpenFOAM 0 July 30, 2012 21:39
