[Commercial meshers] FluentMeshToFoam errorplease help me |
March 1, 2006, 20:15 |
Andy Cong
This is a 2D centeralpump model. When simulate it in Fluent, I set with two fluid zones, one is stationary and the other is rotating(reference). But when I import the mesh to OpenFOAM, errors appears as following: /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.2 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : fluentMeshToFoam /home/andycong/OpenFOAM/andycong-1.2/run/tutorials/simpleFoam 2Dcenteralpump /home/andycong/2Dcenteralpump/pump_mesh.msh Date : Mar 02 2006 Time : 09:09:01 Host : linux PID : 10727 Root : /home/andycong/OpenFOAM/andycong-1.2/run/tutorials/simpleFoam Case : 2Dcenteralpump Nprocs : 1 Create time Dimension of grid: 2 Number of points: 2567 Reading points number of faces: 7263 Reading mixed faces Reading mixed faces Reading mixed faces Reading mixed faces Reading mixed faces Reading mixed faces Number of cells: 4690 Reading uniform cells Reading uniform cells Reading zone data Reading zone data Reading zone data Reading zone data Reading zone data Reading zone data Reading zone data Reading zone data FINISHED LEXING dimension of grid: 2 Grid is 2-D. Extruding in z-direction by: 14.4162 Creating shapes for 2-D cells Creating patch for zone: 4 start: 1 end: 173 type: wall name: wall_3 Creating patch for zone: 5 start: 174 end: 263 type: wall name: wall_2 Creating patch for zone: 6 start: 264 end: 479 type: wall name: wall_1 Creating patch for zone: 7 start: 480 end: 498 type: outflow name: outlet Creating patch for zone: 8 start: 499 end: 546 type: velocity-inlet name: inlet Creating patch for zone: 10 start: 547 end: 7263 type: interior name: default-interior Patch 10 contains solid or internal faces. Not added to boundary Not adding to internal boundaries Creating patch for front and back planes Default patch type set to empty --> FOAM FATAL ERROR : Trying to specify a boundary face 4(0 1 2568 2567) on the face on cell 399 which is either an internal face or already belongs to some other patch. This is face 0 of patch 1 named wall_2. From function polyMesh::polyMesh ( const IOobject& io, const pointField& points, const cellShapeList& cellsAsShapes, const faceListList& boundaryFaces, const wordList& boundaryPatchTypes, const wordList& boundaryPatchNames, const word& defaultBoundaryPatchType ) in file meshes/polyMesh/createPolyMesh.C at line 375. FOAM aborting Aborted Could anyone tell my what's the matter? |
March 2, 2006, 05:42 |
I have the same problem. I thi
Eugene de Villiers
Rep Power: 21 |
I have the same problem. I think it is related to the zone interfaces. Will be looking into it soon.
March 2, 2006, 13:37 |
Hi Andy,
The only Fluent me
Eugene de Villiers
Rep Power: 21 |
Hi Andy,
The only Fluent mesh I have that has this problem consists of 13million cells. As you can imagine it is a bit hard to find the problem when the core dump takes 10 mins. Could I please have a copy of your mesh to do my testing on? |
March 2, 2006, 19:46 |
Of cource it is OK.
Now I wil
Andy Cong
Of cource it is OK.
Now I will attach it in this board. Yestoday when I searched the messages before, I found it seemed that OpenFOAM does not support rotating machine, what do you think of that? |
March 2, 2006, 19:51 |
Of cource it is OK.
Now I wil
Andy Cong
Of cource it is OK.
Now I will attach it in this board. Yestoday when I searched the messages before, I found it seemed that OpenFOAM does not support rotating machine, what do you think of that? I have sent the mesh to your Email. |
March 3, 2006, 07:27 |
Thanks, got it. Will post the
Eugene de Villiers
Rep Power: 21 |
Thanks, got it. Will post the fix when I find it.
March 7, 2006, 04:04 |
Hi Andy.
As far as I can t
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Andy.
As far as I can tell the problem seems to be that you have an 'interior wall' (see http://www.cfd-online.com/OpenFOAM_D...ges/1/364.html) What you have to do is define it as INTERNAL in Gambit and export the mesh again. The wall becomes a faceSet. Then use splitMesh to construct two walls from that faceSet (there is a reference to a more detailed description in the thread I referenced above)
March 7, 2006, 08:46 |
Thank you, I will try it.
Andy Cong
March 7, 2006, 11:48 |
Eugene de Villiers
Rep Power: 21 |
fluentMeshToFoam.L
This is still work in progress, but if you compile this instead of the default it will basically ignore internal boundaries (it will however writes them as faceSets). Should take care of all the problems posted above. |
March 7, 2006, 11:52 |
Forgot to mention, this is for
Eugene de Villiers
Rep Power: 21 |
Forgot to mention, this is for 1.3, don't know if it will work for 1.2.
March 8, 2006, 03:14 |
Hi Eugene,
I tried compilin
#11 |
Mélanie Piellard
Hi Eugene,
I tried compiling your file with 1.2.1, but I miss the repatchPolyTopoChanger.H file: fluentMeshToFoam.L:56:36: error: repatchPolyTopoChanger.H: No such file or directory. |
October 2, 2006, 10:50 |
I have read several for
#12 |
anne dejoan
I have read several forum messages about fluenMeahToFoam, and I am still quite confused. I have a mesh created with fluent (.msh file) with some of the boudaries declared as "interior". Is is the first time I am using such complex grid and I couldn't well understand the steps to correctly apply fluentMeshToFoam. First, compiling the above FluentMeshToFoam.L, with OpenFoam 1-3 gives me the following error compilation: ---- fluentMeshToFoam.L: In function 'int main(int, char**)': fluentMeshToFoam.L:1506: error: 'repatchPolyTopoChanger' was not declared in this scope fluentMeshToFoam.L:1506: error: expected `;' before 'repatcher' fluentMeshToFoam.L:1509: error: 'repatcher' was not declared in this scope make: *** [Make/linuxGcc4DPOpt/fluentMeshToFoam.o] Error 1 ---- Then, reading older forum messages I could see that this could be dealt with splitMesh, but it is still very confusing for me the steps to follow. Thanks you if you could help, PS: I have also simply applied the original version of the fluentMeshToFoam application and have the following message: ------------------------ Patch 23 contains solid or internal faces. Not added to boundary Not adding to internal boundaries Default patch type set to empty Checking mesh Writing mesh Only one cell group: no set written Anne |
October 3, 2006, 04:17 |
Hello again,
Well I have fo
#13 |
anne dejoan
Hello again,
Well I have found on wiki server the information for dealing with interior cell. BUT, the problem I have is that fluentMeshToFoam does not create any faceSet, which means no subdirectory sets in the constant/polyline/ so that when running splitMesh the name of the interior BC from Gambit is not given. I have OpenFoam 1.3 from a linux binary package. Why the subdirectory is not created ? n my previous mail I made a copy of the .msh file and there is one interior BC. Thanks if you can help with this, anne |
October 5, 2006, 05:05 |
What is the output of fluentMe
#14 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
What is the output of fluentMeshToFoam?
In the distributed version if your "interior wall" has been set in Gambit to one of the types "interior", "internal", "solid", "fan", "radiator" or "porous-jump" a faceSet should be generated. The last few lines of the MSH-file would be helpful to diagnose the problem(the ones starting with '(0 "Zones:")')
October 5, 2006, 08:28 |
Hello Bernhard,
I have now
#15 |
anne dejoan
Hello Bernhard,
I have now fixed the problem. Having seen zones declared as "interior" in my .msh I have read all th threat around. However, they were not wall BC but, a zone that is created by default with Gambit (it was the first I used it). This zone is actually ignored by fluentMeshToFoam and I could run my job . Thanks you for anser, Anne |
November 3, 2007, 09:28 |
I use a membrane in my reactor
#16 |
Danielle PRL
I use a membrane in my reactor. It is an internal wall declared as INTERNAL, because I know that Foam don't accept a internal wall. In Fluent my mesh "reactor.msh" with two different zones is good. But when I convert it by fluentMeshToFoam I can't see the membrane (it is an internal wall
declared as INTERNAL). when I check for faceSet in order to make the steps written by "Bernhard Gschaider", I don't find it. Please can you tel me what should I do step by step? 1) fluentMeshToFoam . reactor reactor.msh (no problem) 2)?? 3)?? Thanks |
November 4, 2007, 10:05 |
Is it a 3D mesh?
If so, set u
#17 |
Francesco Del Citto
Rep Power: 18 |
Is it a 3D mesh?
If so, set up as usual the Fluent case (with shadow surfaces), save the case in ascii and use the new "fluent3DMeshToFoam" (OpenFOAM 1.4.1) instead. It should cope with this kind of meshes, now... Francesco |
November 5, 2007, 04:47 |
Hi Danielle!
In recent vers
#18 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Danielle!
In recent versions of fluentMeshToFoam you have to trigger the writing of sets (or zones) with the option -writeSets (or -writeZones). Have you done that? (It's usually a good idea to have a look at the available options with -h if a command does not behave as expected) Bernhard PS: liked the quotes around my name which suggest that I'm a fictitious person. Damn, my secret has been revealed ;)
November 5, 2007, 16:43 |
Hi Bernhard and Francesco,
Th
#19 |
Danielle PRL
Thank you for yours answers. IT WORK NOW! to Bernhard you are the real one in the Matrix :-) |
fluentMeshToFoam - Volume Fields | aylalisa | OpenFOAM Pre-Processing | 7 | May 16, 2017 13:18 |
[Commercial meshers] Converting an abaqus mesh using matlab scripts and fluentMeshToFoam | MichaelD | OpenFOAM Meshing & Mesh Conversion | 1 | July 2, 2014 06:34 |
[Commercial meshers] fluentMeshToFoam instead of fluent3DMeshToFoam | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | March 29, 2013 07:58 |
[Commercial meshers] FluentMeshToFoam | CRT | OpenFOAM Meshing & Mesh Conversion | 3 | May 24, 2012 16:07 |
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam | jlpelerin | OpenFOAM Meshing & Mesh Conversion | 4 | April 25, 2011 16:56 |
