[Netgen] System error during meshing
Old   October 11, 2006, 04:48
Default System error during meshing
ares_tum
I got a very complicated geometry (no warning or error when imported by netgen), which is being meshed by netgen now. The meshing takes at least 2 hours, but still around 99.8%. It shows in the command window that:
"System error: hash table si not fitting for segment: ..."
Does anyone know what's the problem?
Thanks in advance.
Old   October 11, 2006, 04:51
Default sounds like you ran out of mem
Hrvoje Jasak
sounds like you ran out of memory: this must be a pretty big mesh!
Hrv
Hrvoje Jasak
Old   October 11, 2006, 05:03
Default This is the model.
ares_tum
This is the model.
Old   October 11, 2006, 05:06
Default Here is the model, could anyon
ares_tum
Here is the model, could anyone try to mesh it?
Thanks
stl.zip
Old   October 11, 2006, 06:53
Default There are a lot of intersectin
christian_hausmann
There are a lot of intersecting elements in your model.
Can you change the settings of you CAD program to get a better stl-file?
Netgen needs a almost perfect geometry to finish meshing.
Old   October 11, 2006, 07:10
Default Thanks for your answer,Christi
ares_tum
Thanks for your answer,Christian.
The original model is downloaded from internet. I just cut one part out, and added a top onto it.
Could you please tell me where do the intersecting elements locate? On the top, bottom,or lateral surface? How to solve it?cad?
Thanks
Old   October 11, 2006, 07:48
Default They are spread over the hole
christian_hausmann
They are spread over the hole surface. Use a CAD program. Try to vary the features of the stl-export-function. (more accuracy) What's you CAD program?
Old   October 11, 2006, 08:25
Default I think i can see them now in
ares_tum
I think i can see them now in netgen. Really a lot. I am not familiar with cad and don't have any cad program in my computer. Are there any other possibilities? Or i have to modify them by hand
Thanks a lot.
Old   October 12, 2006, 03:18
Default You can try to use the stl-doc
christian_hausmann
You can try to use the stl-doctor.
Change "Double Click selects:" to "triangle" and select one blue-edged triangle, or Deselect "select with mouse", Insert the number of an intersecting triangle below.
After selecting an intersecting triangle use "move point to middle of trianglepoints". Maybe 0-volume-triangles were generated, delete them. Save the geometry.
Be sure that you exclusively insert the number of an intersecting element. Select an triangle with mouse is not always as easy as it seems.
Old   October 12, 2006, 04:14
Default Great thanks, Christian. I'll
ares_tum
Great thanks, Christian. I'll try it.
Old   October 30, 2006, 13:37
Default Hi Zhengxiong, I had a look
  #11
Philippose Rajan
philippose will become famous soon enough
Hi Zhengxiong,
I had a look at your STL file in Netgen, and tried a moderate mesh generation... Here is a screen-shot of the result I got... I have marked in red the areas (there are more on the rear side), where Netgen is having trouble closing the mesh due to inconsistent and intersecting triangles....
As Christian Hausmann suggested, I think you need an STL export with finer triangles defining the surface....
Philippose
philippose is offline   Reply With Quote
Old   October 30, 2006, 13:40
Default Oops.... Looks like the file d
  #12
Philippose Rajan
Oops.... Looks like the file didnt get uploaded... second try :-)
Philippose
Old   October 30, 2006, 13:45
Default Looks like Firefox in Linux fo
  #13
Philippose Rajan
Looks like Firefox in Linux for some reason doesnt support this possibility of uploading files.... any suggestions from anyone ??
Sorry for flooding the message board :-)!
Philippose
Old   October 31, 2006, 12:56
Default Hi Philippose, Just a test
  #14
Mattijs Janssens
mattijs is on a distinguished road
Hi Philippose,
Just a test to see if the uploading works from konqueror. You are aware of the 50k limit?
unitCube.stl
mattijs is offline   Reply With Quote
Old   October 31, 2006, 13:55
Default Hi, 50k limit :-)!! Oh my...
  #15
Philippose Rajan
50k limit :-)!! Oh my... no wonder... its all clear now :-)! The image was 450Kb... but well, with some Gimping and rescaling, I have it down to 12.5Kb... lets see if it works now :-)!
Thanks for pointing out the limit Mattijs :-)!
Philippose
CFD post cannot load results-Error appeared? mariam.sara ANSYS 9 September 17, 2018 15:23
[ANSYS Meshing] meshing time system shows script error/IC ENGINE Phantomz ANSYS Meshing & Geometry 0 January 25, 2018 01:02
[ANSYS Meshing] Icem meshing queries Mfaizan ANSYS Meshing & Geometry 21 July 30, 2015 23:10
Meshing software comparison Wikie Mesh Generation & Pre-Processing 5 September 29, 2014 06:09
Need ideas-fuel discharge system Jan FLUENT 1 October 10, 2006 23:05
