[blockMesh] Embedded blocks
Old   July 16, 2010, 11:13
Default Embedded blocks
Robertas N.
r08n is on a distinguished road
Hi all,
I need to define a hex block inside a rectangular computational domain, which is basically a block also. Is there any possibility to define a smaller block inside a larger block, like e.g. this:
vertices
    (0 0 0)	// 00
    (15 0 0)	// 01
    (15 6 0)	// 02
    (0 6 0)	// 03
    (0 0 6)	// 04
    (15 0 6)	// 05
    (15 6 6)	// 06
    (0 6 6)	// 07
    (5 1 2)	// 08
    (12 1 2)	// 09
    (12 4 2)	// 10
    (5 4 2)	// 11
    (5 1 5)	// 12
    (12 1 5)	// 13
    (12 4 5)	// 14
    (5 4 5)	// 15
blocks
    hex (0 1 2 3 4 5 6 7) (30 12 12) simpleGrading (1 1 1)
    hex (8 9 10 11 12 13 14 15) block_porosity (14 6 6) simpleGrading (1 1 1)
blockMesh and checkMesh run without choking, but the actual application stops with the message: "The mesh contains patches of type empty but is not 1D or 2D".
I need the setup of the above type to simulate flows in porous media because the standard way to define porous zones is to define the blocks and associate the porous zones with the appropriate blocks. How to implement the setup where the porous media only partially fills the overall domain? Define multiple blocks that tile the 3D domain?
r08n is offline   Reply With Quote
[Commercial meshers] fluent3DMeshToFoam bego OpenFOAM Meshing & Mesh Conversion 31 August 16, 2023 09:04
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface manuc OpenFOAM Meshing & Mesh Conversion 1 July 25, 2017 03:13
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
