[Commercial meshers] OpenFOAM cannot read the mesh .neu (GAMBIT mesh file)
Like Tree3Likes
Old   October 3, 2011, 14:33
Default OpenFOAM cannot read the mesh .neu (GAMBIT mesh file)
spk
spk is on a distinguished road
Hi guys,
I use ubuntu system in order to run openFoam.
I created a 2D mesh using Gambit (orifice.neu)
I saved this file in a folder.
Using terminal i find this folder and type
gambitToFoam orifice.neu
Then terminal writes:
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/spyros/OpenFOAM/spyros-2.0.1/run/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Where is the problem?
Can you help me?
Thanks a lot,
spk
spk is offline   Reply With Quote
Old   October 4, 2011, 02:33
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
Originally Posted by spk View Post
Hi guys,
cannot find file
You have to set up an OpenFOAM case before you can do the mesh conversion, i.e. a system folder containing a controlDict file.
zaynah04 likes this.
akidess is offline   Reply With Quote
Old   November 17, 2012, 03:38
zaynah K.
zaynah04 is on a distinguished road
hi Anton,
i have looked a lot on net, but have not find any step by step method on how to create an openfoam case before doing the conversion.. i have followed some steps but all the time after i run the fluent3DMeshToFoam, i obtain that command not find..
can you please find some time and explain to me how to proceed stepwise..
i am new to openfoam..
thanks a lot..
zaynah
zaynah04 is offline   Reply With Quote
Old   November 17, 2012, 11:32
zaynah K.
i have followed this:
In order to convert a mesh to OpenFOAM format it suffices to make the following steps:
  • Create an OpenFOAM directory case structure:
    • mkdir casename
    • mkdir casename/system
    • mkdir casename/constant
    • mkdir casename/constant/polyMesh
    • mkdir casename/0
  • Create the controlDict file which contains temporal evolution information (see the OpenFOAM User Guide):
    • vi casename/system/controlDict
  • Create the files for setting the solutor and other stuffs (see the OpenFOAM User Guide):
    • vi casename/system/fvSchemes
    • vi casename/system/fvSolution
  • Run the appropriate library:
    • library < caseroot > < casename > < meshfile >
      for example, if the case has been created in the current directory:
    • fluent3DMeshToFoam . casename file.msh
But each time i come to
my system freeze over..;(
Old   November 19, 2012, 08:05
-mAx-'s Avatar
Maxime Perelli
copy a case in the tutorial folder and paste it into your /run directory.
Then adapt all files especially
/0/U
/0/p
/0/k
/0/epsilon
/constant/transportProperties
/constant/RASProperties
Old   November 19, 2012, 08:13
zaynah K.
thanks Max,
it worked...
now i do not understand how to use the boundary condition in openfoam!
I had use 4m/s in fluent and k-upsilone
Also i use velocity inlet outflow and wall..
now i am lost as how to proceed..
Old   November 19, 2012, 08:19
-mAx-'s Avatar
Maxime Perelli
now you can import your mesh.
Once it is done, you should have in contant/polyMesh a boundary file.
In this file you will retrieve all the patches you defines in Gambit.
Then in:
/0/U
/0/p
/0/k
/0/epsilon
enter right patch names and right boundary conditions
Then don't forget that in Gambit your model is not scaled. In OF you can do it with transformPoints
Then chekMesh
Then specify turbulence models in /constant/RASProperties and viscosity in /constant/transportProperties.
Finally if you copied a tutorial for you wanted solver, you can start in serial.
hope it helped
Old   November 19, 2012, 08:39
zaynah K.
hi
mesh was imported successfully..
i am newbie and a bit unfamiliar with all those terms..
after i change the boundary condition, what do i do in the terminal? i mean what command to use?
Old   November 19, 2012, 08:43
-mAx-'s Avatar
Maxime Perelli
if everything is ready, then you can simple type name of your solver
>simpleFoam
for instance
Old   November 19, 2012, 09:09
zaynah K.
fileName::stripInvalid() called for invalid fileName UbuntuOne
For debug level (= 2) > 1 this is considered fatal
Aborted (core dumped)
i get this error after type icoFoam..
Old   November 19, 2012, 09:12
-mAx-'s Avatar
Maxime Perelli
ok no idea about this error.
Just to be sure: again copy and paste the tutorial, and run it
is it cavity tutorial?
Old   November 19, 2012, 09:27
zaynah K.
yes cavity tutorial..
Old   November 19, 2012, 09:29
-mAx-'s Avatar
Maxime Perelli
and?
can you run the tutorial?
>blockMesh
>icoFoam
Old   November 19, 2012, 09:30
zaynah K.
yes of course..
Old   November 19, 2012, 09:34
zaynah K.
can i modify my parameters in that folder system/foamData to fluent dict?
i found that i can change directly paramters there example
p 1;
U 2;
T 3;
h 4;
k 5;
epsilon 6;
gamma 150;
-mAx-'s Avatar
Maxime Perelli
ok it sounds good.
Now go to your case, and paste here what's in:
* /constant/polyMesh/boundary
*0/U
*0/p
Old   November 26, 2012, 04:05
zaynah K.
hi
in the dimensions units
1 for mass
2 for length etcc...
we have all 7 parameters but in the book i found parameter -1 what does it mean? from my dimensions unit the third parameter means time...we cannt have negative time..
what does [ 0 2 -1 0 0 0 ] the -1 means?
thanks
Old   November 26, 2012, 04:32
-mAx-'s Avatar
Maxime Perelli
here -1 means 1/s
[ 0 2 -1 0 0 0 ] --> m**2/s
Old   November 26, 2012, 04:55
zaynah K.
hi
You mean 2 m/s?
but in the dimension unit is a list of 7 units..i though the parameters inside the brackets corresponded with the units.
Old   November 26, 2012, 05:01
-mAx-'s Avatar
Maxime Perelli
[m**2/s] = [m^2/s] = [m*m/s] = square meter per second
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
