February 12, 2013, 08:44 |
snappyHexMesh error
patrick okolo
Rep Power: 14 |
Gooday all, pls am currently trying to mesh a car geometry i downloaded online, i changed the motorBike snappyhexMesh dict, by simply changing the motorBike.stl to R8.stl which is my own car geometry. on running snappyHexMesh on my terminal, the following errors were gotten.
Create mesh for time = 0 Read mesh in = 0.02 s Overall mesh bounding box : (-5 -4 0) (15 4 8) Relative tolerance : 1e-06 Absolute matching distance : 2.29783e-05 word::stripInvalid() called for word For debug level (= 2) > 1 this is considered fatal please advice me on how 2solve this. thanks |
February 12, 2013, 08:49 |
patrick okolo
Rep Power: 14 |
please your advice is urgently needed
February 12, 2013, 10:26 |
Daniel P. Combest
Maybe you could try using HELYX-OS. There is an ongoing discussion at http://www.cfd-online.com/Forums/ope...pyhexmesh.html
For some more detailed information about snappyHexMesh and running from the command line, see the article about SnappyHexMesh on the OpenFOAM wiki Disclaimer: I work for the company that produces HELYX-OS. Last edited by chegdan; February 12, 2013 at 10:35. Reason: added disclaimer |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
