[Salome] Converting Salome wedge mesh to OpenFOAM
Old   March 8, 2019, 22:50
Default Converting Salome wedge mesh to OpenFOAM
anon_q is on a distinguished road
I created a wedge mesh using Salome, But unfortunately after trying to convert it:
ideasUnvToFoam wedge_mesh.unv
But unfortunately the script fails to convert it with the following error:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
Build  : 6-e29811f5dff8
Exec   : ideasUnvToFoam wedge_mesh.unv
Date   : Mar 09 2019
Time   : 04:38:09
Host   : "myPC"
PID    : 20428
I/O    : uncollated
Case   : /home/evlin/openfoam_sims/rotate-mesh
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Processing tag:164
Starting reading units at line 3.
l:1
units:"  SI: Meter (newton)"
unitType:2
Unit factors:
    Length scale       : 1
    Force scale        : 1
    Temperature scale  : 1
    Temperature offset : 273.15
Processing tag:2420
Skipping tag 2420 on line 9
Skipping section at line 9.
Processing tag:2411
Starting reading points at line 20.
Read 2013 points.
Processing tag:2412
Starting reading cells at line 4049.
First occurrence of element type 11 for cell 1 at line 4050
First occurrence of element type 44 for cell 211 at line 8220
First occurrence of element type 41 for cell 1177 at line 10140
First occurrence of element type 115 for cell 1357 at line 12428
First occurrence of element type 112 for cell 1567 at line 12848
Read 960 cells and 2104 boundary faces.
Processing tag:2467
Starting reading patches at line 14350.
For group 1 named inlet trying to read 30 patch face indices.
For group 2 named outlet trying to read 30 patch face indices.
For group 3 named top trying to read 32 patch face indices.
For group 4 named bottom trying to read 32 patch face indices.
For group 5 named inlet trying to read 30 patch face indices.
For group 6 named inlet_top trying to read 30 patch face indices.
For group 7 named outlet trying to read 30 patch face indices.
For group 8 named outlet_top trying to read 30 patch face indices.
For group 9 named top trying to read 32 patch face indices.
For group 10 named top_top trying to read 32 patch face indices.
For group 11 named wedge_2 trying to read 960 patch face indices.
For group 12 named wedge_1 trying to read 960 patch face indices.
Found 960 reversed boundary faces out of 2104
Of 2104 so-called boundary faces 92 belong to two cells and are therefore internal
Sorting boundary faces according to group (patch)
0: inlet is faceZone
--> FOAM FATAL ERROR:
1 not found in table.  Valid entries:
2104
4096
4097
4098
4099
4100
4101
4102
4103
4104
4105
4106
4107
4108
4109
// I skipped a long list of number
 From function T& Foam::HashTable<T, Key, Hash>::operator[](const Key&) [with T = int; Key = int; Hash = Foam::Hash<int>]
    in file /home/ubuntu/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude/HashTableI.H at line 117.
FOAM exiting
  • Is it possible to convert Salome wedge mesh to OpenFOAM?
anon_q is offline   Reply With Quote
Old   March 11, 2019, 12:14
Peter Hess
peterhess is on a distinguished road
Hello Linda!
Try the following:
- Download the script:
salomeToOpenFOAM.py
from here:
https://github.com/nicolasedh/salomeToOpenFOAM
and save it to your working folder
- Generate the mesh you want to convert and save the *.hdf file (SALOME)
- In SALOME mark the mesh you want to export
- File -> load script -> salomeToOpenFOAM.py
- Wait until the mesh exported. Finished exporting is printed in SALOME console
- A new folder will be generated in your case called mesh(_1) and includes the mesh
- Copy the mesh folder (polyMesh) to constant
Regards
Peter
peterhess is offline   Reply With Quote
Old   March 12, 2019, 20:16
Thank you dear Peter, I tried to download the script above but unfortunately it fails to convert the mesh.
Currently I cannot post the error message (Something is going wrong with this forum)
Old   March 13, 2019, 01:27
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Please share you HDF file so we can see what you have been doing.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   March 13, 2019, 15:13
Recently I encounter a very strange error in this forum when trying to post or send a message that contains some code!!!!!!
It doesn't let me post the error message here!
Converting Salome hybrid mesh to OpenFOAM Arnoldinho OpenFOAM 4 March 28, 2012 10:24
Mesh conversion problem from Salome to openfoam jishnusoni OpenFOAM 15 March 3, 2010 01:53
[Gmsh] Error converting Gmsh mesh to OpenFOAM format Martin_ OpenFOAM Meshing & Mesh Conversion 3 December 9, 2009 09:35
salome, openfoam and moving mesh prhlava OpenFOAM Running, Solving & CFD 8 November 9, 2009 08:59
