[snappyHexMesh] snappyHexMesh after extrudeMesh / Creating background mesh with extrudeMesh
Old   August 12, 2013, 05:00
Default snappyHexMesh after extrudeMesh / Creating background mesh with extrudeMesh
pythag0ra5 is on a distinguished road
Dear FOAMers,
i want to run a procedure like:
1.) blockMesh
2.) snappyHexMesh -overwrite
3.) extrudeMesh
4.) snappyHexMesh -overwrite
In other words, the background mesh for the second snappyHexMesh-procedure should be created with extrudeMesh. My problem is, that the steps 1-3 works fine, but when i run SHM again (Step 4), i get an error-message:
--> FOAM FATAL ERROR:
Number of cells in mesh:16328 does not equal size of cellLevel:236700
This might be because of a restart with inconsisten cellLevel.
I asume, that i have to delete some files / directories, but as i am not sure about this, it would be very nie if you can gie me a hint!
Best regards!
pythag0ra5 is offline   Reply With Quote
Old   September 11, 2013, 05:36
Artur's Avatar
Artur
Artur will become famous soon enough
It's quite an old post, have you figured out the solution?
My bet would be:
a. delete all the cell sets, face sets, etc. from the polyMesh directory
b. remove all the files created by snappy in the 0 directory
c. check that all your boundaries are defined properly after the extrude mesh procedure; if not then use topoSet and/or createPatch -overwrite to create new patches or remove those with 0 faces in them
Artur is offline   Reply With Quote
Old   September 11, 2013, 08:40
Hi Artur,
thank you very much for your reply, unfortunately my problem is not solved yet.
Meanwhile, i found out that some files in the polyMesh-directory have to be deleted (as you already mentioned in your post).
Right now, i think my that there is no solution for my desired procedure. This is because snappyHexMesh requires a background mesh which consists (only) of hexahedral elements. But an arbitrary shaped geometry will lead also to tetrahedral- / layer- / other elements, therefore (in my opinion), snappyHexMesh can only be used one time.
Best regards
Mathias
Old   September 11, 2013, 09:10
Artur's Avatar
Artur
Well too bad it didn't work, would have been a nice tool.
Thanks for sharing your conclusions anyway!
extrudemesh, snappyhexmesh, snappyhexmesh 2d
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
snappyHexMesh superimposition of background grid and surface mesh OF2.4, PV4.1.0 deepbandivadekar OpenFOAM Running, Solving & CFD 0 November 12, 2017 19:06
[snappyHexMesh] SnappyHexMesh .stl Jochem OpenFOAM Meshing & Mesh Conversion 10 September 23, 2016 04:26
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[Gmsh] background mesh in gmsh Nick_J OpenFOAM Meshing & Mesh Conversion 1 March 20, 2013 04:20
